Title: Changing Steering Wheel Airbag Post by: Paul Greenway on 30 November, 2017, 09:23:13 PM I have just purchased a Lancia Delta Steering Wheel centre which contains the Airbag. I want to remove the current Chrysler Delta centre & replace with the Lancia item. Everything except the badging appears to be exactly the same so I am assuming that the contents & wiring are all the same and it will be a straightforward exchange. Does anyone know the procedure of swapping one for the other? All advice welcome, thanks. Paul Title: Re: Changing Steering Wheel Airbag Post by: neil-yaj396 on 05 December, 2017, 07:21:31 AM Was told this was a main dealer job? Old airbag needs to be deactivated. Hence only Chrysler badge still on my Ypsilon .
Title: Re: Changing Steering Wheel Airbag Post by: frankxhv773t on 05 December, 2017, 04:51:10 PM There are videos on youtube about doing the job. It doesn't seem to require any special equipment just the right safety precautions. https://www.youtube.com/watch?v=Hadsvt17Fj0
Title: Re: Changing Steering Wheel Airbag Post by: Paul Greenway on 11 December, 2017, 09:11:10 PM Mines being exchanged tomorrow along with the grille at an independent Volvo dealers that Claire swears by. Will tell you how it went.
Title: Re: Changing Steering Wheel Airbag Post by: Paul Greenway on 12 December, 2017, 05:53:48 PM Both original OE Lancia airbag steering wheel and OE Lancia 'Momo' grille fitted to my Delta. No problem £55.00 for the privilege - money well spent. Photo's to follow once it gets light.
