Model Technical and Interest => Fulvia => Topic started by: acalex on 11 May, 2018, 05:45:24 PM
Title: sump capacity 1600HF
Post by: acalex on 11 May, 2018, 05:45:24 PM
In my Fulvia handbook it quotes the sump etc capacity as 4.3L. There is no addendum/changes in the rear of said handbook re capacities for the 1600HF, so I assumed it was the same.
Having just changed oil and filter, I carefully added a bit under 5L to get things going, still not at the MIN level on the dipstick. Added a bit more, same result, put in the remainder of can, just on MIN, so added a bit more from a new can.
So you can see the reason for my question, ie is the 1600HF capacity more than 5L??
Any advice welcomed....
Title: Re: sump capacity 1600HF
Post by: Zaggy on 11 May, 2018, 07:08:55 PM
Engine oil capacity for 1.6 S2 is 4.75 litres. The S1 1.6 oil capacity is 5.80 litres.
Post by: acalex on 11 May, 2018, 10:13:59 PM
Thanks but thats strange as mine is definitely an S2.....will be guided by the dipstick
Post by: simonandjuliet on 12 May, 2018, 06:33:37 AM
Do you have an oil cooler fitted ? That would account for the difference, I think . An s2 hf doesn’t have one fitted as standard- does a Fanaloni?
Post by: stanley sweet on 12 May, 2018, 09:43:55 AM
Might be a stupid suggestion but is the dipstick the correct length? I don't have 1600 so can't provide a measurement.
Post by: acalex on 12 May, 2018, 09:49:22 PM
good thought about an oil cooler, but not one fitted....also a good question about the correct dip stick, but will probably never know the answer to that one! all I can say is it looks correct, but who knows.
its one of those really simple things, ie an oil change, that shouldn't cause any particular issues, but there you go....
Post by: lancialulu on 13 May, 2018, 08:15:54 AM
It will not make much difference but some alternative oil filters are larger than the oem. It may be that a previous owner obtained and fitted a Fanalone sump for extra capacity. I hope he will have fitted the longer oil pick up as well (if that was the case)!!
Post by: davidwheeler on 13 May, 2018, 03:45:00 PM
My series 2 1600 Sport, which has the same engine I believe, dipstick measures 233mm from the shoulder of the black plastic plug to the full mark.
Post by: acalex on 13 May, 2018, 06:00:14 PM
thanks for the measurement....so the mystery deepens as mine from the shoulder to max is 245mm, which logic tells me means my oil level should be up to max with less oil in the sump?!
Could it be a Fanalone sump as suggested, again no idea and is there any easy way to tell?
In the meantime the concern is how much oil to actually put in, and to where on the dipstick, as am already a bit over 5l
Post by: angelorange on 23 May, 2018, 11:17:31 PM
Works S1 sump is over 6 litres. Best way to measure is gradually add oil and mark dip stick. Works sump much wider than normal one.
