Title: Lancia Fulvia 1600hf, 'relay for ignition' Post by: stuhf on 21 May, 2018, 07:07:47 PM Hello
I am having trouble starting my Lancia,when i turn the ignition key the car turns over however the ignition and choke lights are not on! Is their a relay that could be at fault? If so where is it located? and is their a model number for this? Any help would be appreciated! Thanks Stuart Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: lancialulu on 22 May, 2018, 07:45:49 AM No relay. Seems you may have a few wiring faults and also fuel/ignition problems. Get a owners handbook/concise manual and study the wiring diagram for the HF.
Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: SJWhite on 23 May, 2018, 10:16:25 PM Hi Stu
I have the same problem sometimes - the Red Charging Light goes out along with the Choke Light. The engine turns over however will not fire. Very odd Cheers Simon Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: stuhf on 24 May, 2018, 06:08:43 PM Hello Simon, I did fit a new ignition and Lancia was starting with no problems last year, been in garage for winter and had a few drives out during good weather however recently having this problem! thanks Stuart Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: nistri on 29 May, 2018, 07:13:21 AM Check fuse #1 and its wiring (first on the left), Andrea
Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: stuhf on 29 May, 2018, 05:49:20 PM Thank you Andrea for that information, I will have a look at that this weekend. regards Stuart Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: Fulviaclassics on 23 September, 2018, 07:20:37 PM How did you get on with this fault?
Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: davidwheeler on 24 September, 2018, 04:05:31 PM Fulvia fuses and fuse boxes are notorious. The corrosion between the wire and the terminal is part of the problem, not just the contact between fuse and post. Some people solder the wires to the posts but it needs a big soldering iron. I eliminated the problem in the Aprilia by soldering fuse wire across the posts instead of removable fuses (with some spare conventional fuses in the glove box case) but the Aprilia has only 5 fuses!
Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: Dave Gee on 24 September, 2018, 04:27:08 PM Only just noticed this thread, and hope you have solved your problem. I had a similar problem coming back from classic le mans; the engine would turn over but no ignition or choke lights on. The problem was due to mucky contacts in the ignition switch. The immediate 'get you home' solution was to hotwire the ignition. I have since stripped and cleaned the contacts within the ignition switch and now everything works well.
Best wishes Dave Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: Fulviaclassics on 26 September, 2018, 10:42:20 AM Hi David, I think you're right, I've ordered a new ignition from Italy so will give it a go.
Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: chriswgawne on 26 September, 2018, 12:18:15 PM I have several 'as new' Fulvia S1 ignition locks + keys.
Chris Title: Re: Lancia Fulvia 1600hf, 'relay for ignition' Post by: Fulviaclassics on 06 October, 2018, 07:03:05 PM Just to update, the problem was the ignition lock, I bought a new one and plugged it in both problem cars and perfect!
