Model Technical and Interest => Fulvia => Topic started by: jimbo64 on 18 January, 2019, 08:09:56 PM
Title: What is this for
Post by: jimbo64 on 18 January, 2019, 08:09:56 PM
Hi as title not sure what this is for
Title: Re: What is this for
Post by: IanC on 18 January, 2019, 10:45:56 PM
Well I don’t have one on mine
Post by: jimbo64 on 18 January, 2019, 11:05:22 PM
Apparently not many do
Post by: Richard Fridd on 19 January, 2019, 10:37:54 AM
Is it a bracket for an engine bay light switch?
Post by: frankxhv773t on 19 January, 2019, 10:46:31 AM
These two pictures seem to have it but not as a light switch mount.
Post by: Richard Fridd on 19 January, 2019, 06:17:14 PM
Is there a silver component in the same area (second photo)?
Post by: frankxhv773t on 19 January, 2019, 07:33:35 PM
I think the silver component IS an under bonnet light switch but that it is a on a separate, horizontal mounting tang. I wasn't sure the top picture didn't show a rubber hose going through the vertically orientated fitting.
Post by: jimbo64 on 19 January, 2019, 08:00:37 PM
A closer look
Post by: fay66 on 20 January, 2019, 12:15:40 AM
There is definitely a flick switch in the second photo, that would appear to be nothing to do wth the first photo which seems to be a cable of some sort, there is no sign of this in the 2nd photo at the bracket or under the air box, however there is a cable clamped to the inner wing panel that I suspect is something to do with the switch ???
Seems odd though that it's a welded bracket?
8227 8)
Post by: lancialulu on 20 January, 2019, 08:13:33 AM
The hole in it is grommet sized so a cable would be obvious.
Post by: SanRemo78 on 20 January, 2019, 09:28:38 AM
Does the Fulvia have an under bonnet light?
Post by: stanley sweet on 20 January, 2019, 10:45:46 AM
My S2 has a festoon bulb attached to the underside of the bonnet. Not sure about S1's. It seems typically Lancia to produce and weld that bracket just to hold a pipe when they could have used clips on the wheel arch similar to the oil cooler pipes on the opposite side. I haven't seen this bracket before either.
Post by: lancialulu on 20 January, 2019, 11:08:15 AM
Festoon is mounted on middle of bonnet underside on S2 with switch up by bulkhead rain gutter. I think the hole is grommet size so cable with be my thought.
Post by: SanRemo78 on 20 January, 2019, 01:39:26 PM
How about a mounting bracket for an airhorn trumpet?
https://l7.alamy.com/zooms/e5221b6ee9ce414db9b64c2e11f03971/lancia-fulvia-zagato-sport-1600-engine-hdte8e.jpg
Post by: fay66 on 20 January, 2019, 03:33:27 PM
S 1 Bulb holder and switch on my 2c are mounted in the centre in front of the drain channel.
8227  8)
Post by: jimbo64 on 20 January, 2019, 05:53:35 PM
Yay
(http://)
Post by: fay66 on 20 January, 2019, 06:00:57 PM
Yay
(http://)
I had a Series 1, 1969 1.3 Rallye Coupe RHD, and I have series 1 1966 2c Berlina, and neither certainly had/have anything like that.
What year is it?
8227   8)
Post by: jimbo64 on 20 January, 2019, 06:07:13 PM
Looks like 1200 66 cars I found two pictures in 10 mins lol
Post by: simonpen on 25 January, 2019, 05:26:16 PM
My 1965 Coupe has one of these and the black metal enclosure as in the previous engine bay picture. The metal enclosure is held in place with a flat headed screw which passes through the hole in the bracket. The enclosure houses a large Bosch relay connected to I do not know what, starter motor perhaps?
