Buy, Sell and Search => Spares for sale => Topic started by: lsdiff on 07 October, 2019, 01:53:28 PM
Title: Fulvia S2 mechanical and trim parts
Post by: lsdiff on 07 October, 2019, 01:53:28 PM
I have a mountain of Fulvia S2 parts for sale. Make me an offer if anything is of interest. Parts are located in Northamptonshire. I can post smaller parts if needed.
Engine & Gearbox Parts
Engine complete 818.303
Engine block 818.303
Cylinder head with cams
Set of pistons
Solex carbs
Gearbox x2 818.630
Exhaust manifold x3
Exhaust downpipe
Alternator x2 (Ducellier)
Starter motor x 2 (Bosch)
Flywheel
Gear lever
Radiator
Oil filter housing
Solenoid x2
Oil pickup
Distributor cap
Water pump
Distributor x2
Airbox x2
Fuel pump x2
Carburettor drip tray
Brake, Steering and Suspension Parts
Front hub and disc
Brake booster x3
Brake master cylinder fluid reservoir
Brake calliper (Girling)
Steering arms
Drive shaft
Interior Parts
Heater matrix
Front seat back x4 need repair
Lock cylinders and key x2
Stalks
Steering column
Steering column cowl
Centre console plastic
Sunvisors
Heater controls
Ashtray
Vent cover
Centre console
Fulvia dash script
Glove box lid
Arm rests
Dash grab handle
Gear knob
Steering wheel centre
Window winders x6
Inner door handles x4
Dash clock
Set of instruments x3
Seat runners
Glass & Exterior Trim Parts
Rear windscreen
Rear side glass x4
Door locks
Fuel flap lock
Bonnet latch
Wheel centre caps
Headlight rings
Fulvia 3 boot badge badge
Lancia boot badge
Lancia grill badge
"S" boot badge
Lancia script
Fulvia script
1.3S badge
Number plate light x 8
Wing mirror
Outer door handle pair
Rear window closer
Windscreen wiper washers
Rear reflectors
Side indicator lens
Rear light unit
Rear light lens
Headlight
Headlight rings
Front indicator housing
Windscreen wiper arms pair
Front bumpers x2
Rear bumpers x2
Various chrome trim parts
Miscellaneous Parts
Windscreen wiper motor x2
Windscreen wiper mechanism
Offside door lower repair panel
Fuel filler neck
Set of hub tools
Title: Re: Fulvia S2 mechanical and trim parts
Post by: Jaydub on 07 October, 2019, 07:53:05 PM
Hi PM sent to you.
Jaydub
Post by: andyps on 18 October, 2019, 06:50:05 PM
I just messaged and emailed.
Post by: Sean.D on 14 August, 2020, 08:20:25 AM
Hi There , just popped an e-mail off to you, just in case you still have what I'm after.
