Title: 3D Printing for replacement parts Post by: Foggitt on 01 March, 2020, 02:48:08 PM Has anyone any experience of ordering/using 3D replacement parts, as I need a fuse box cover for my Aprilia?
The present one is Bakelite, but I may have to have a non Bakelite replacement made. I’m in Hampshire and would welcome advice if anyone has any experience of 3D parts. Thanks! Andrew Title: Re: 3D Printing for replacement parts Post by: AlanT on 02 March, 2020, 08:39:22 PM Andrew,
I'm a mechanical design engineer and I've made use of 3D printed parts for prototypes, for various work projects going back more than 10 years. In my line of work they are most often used to quickly prototype what will end up being an injection moulded plastic part. I have noticed that the quality and robustness of these parts has improved over the years, but you need to be aware that the 3D part will NOT be as robust as the original part. These parts tend to be more fragile than injection mouldings, or in your case a compression moulded bakelite part. however, sometimes it's possible to thicken up wall sections on the 3D part to make the part more robust. For example, thicken up wall sections around screw fixing points. Have you found a supplier who is able to supply your part? If so, I'd be interested to know what type of material and the type of process they are proposing to use. I'd be happy to advise on suitability. In summary, as it's a fuse box cover, it's probably not under much stress so a 3D printed part could work ok. Is it screwed in position or clamped? Regards, Alan Title: Re: 3D Printing for replacement parts Post by: Kari on 03 March, 2020, 04:38:37 PM Andrew,
If the fuse box cover you are looking for is the one with 6 fuses, then I think those boxes are still available at https://www.vintagecarparts.co.uk/ and from some suppliers in Germany. regards Karl Title: Re: 3D Printing for replacement parts Post by: Foggitt on 03 March, 2020, 09:18:25 PM Karl,
Thank you. I’ve just been looking at them & I’ll need to measure up to see if they might fit. Regards, Andrew |
