Model Technical and Interest => Fulvia => Topic started by: JJC on 01 March, 2020, 05:40:42 PM
Title: Fulvia 1600 HF Strange electrical issues
Post by: JJC on 01 March, 2020, 05:40:42 PM
I’m hoping someone may be able to advise on my cars strange behaviour.
It’s intermittent which makes it worse, so car starts and runs fine, however
for no reason I suddenly loose, all lights including brake lights, wipers, and heater fan
If I switch the car off, everything comes back to life, then when I start the engine again
Everything appears to work again for a while then the same issue, I’ve done all the obvious
checking fuse box etc. There is no issue with the ignition loosing power and cutting the engine.
Any advice appreciated I’m running out of ideas !
Regards
John
Title: Re: Fulvia 1600 HF Strange electrical issues
Post by: rogerelias on 01 March, 2020, 08:14:31 PM
Hi.as a guess there seems possibly to be a high resistance problem somewhere. Check chassis earth, and connections onto starter motor,not sure if there is a fuse by the starter motor.. everything should go through the ignition switch I think. Just a few pointers, I am sure someone on here will come up with other solutions. good luck
Post by: lancialulu on 02 March, 2020, 07:22:17 AM
Is the light switch stalk assembly loose, or broken wire inside it. Seem to recall this happened on my car and that was the culprit. Also maybe the ignition switch?. Look at a wiring diagram.
Post by: Jai Sharma on 02 March, 2020, 07:50:03 AM
the light and/or ignition switch occurred to me too.
Post by: nistri on 02 March, 2020, 08:16:00 AM
Open the fuse box after disconnecting the (-) terminal on the battery. Go to the first fuse on the left, remove it and replace it after careful cleaning of the contacts with a small file to obtain bright metal. Check that the Lucar connectors at the same fuse are OK and that nothing is loose. Andrea
Post by: JJC on 02 March, 2020, 11:37:43 AM
Thanks for advice so far :) I will strip and clean light and wiper stalk and maybe the ignition switch
And re check the fuse box. I think the earths are OK.
Post by: JJC on 02 March, 2020, 08:00:29 PM
So cleaned all the contacts on the lights and wiper stalks
wiring all looks ok, removed and striped the ignition
barrel and there was one dirty contact which was blue/ black
wire which I believe goes back to fuse box. I’ve cleaned it
up and put it back together so will try and get it back in the car tomorrow 🤞
Post by: Jai Sharma on 02 March, 2020, 10:46:05 PM
If that doesn't work it is well worth following the advice Andrea has posted.
Post by: lancialulu on 03 March, 2020, 06:54:33 AM
The lighting switch assembly must be tight on the outer housing and this must be tight also on the steer column as this is where it derives earth. I have seen fibre washers which creates problems...
Post by: JJC on 05 March, 2020, 04:43:11 PM
Not had a change to take the car out yet but everything is back together, and appears to be functioning, Is it normal for the wipers and heater fan to work without key in ignition ? I can also switch lights on with ignition. Horn and indicators require ignition.
Regards
John
Post by: JJC on 05 March, 2020, 04:45:57 PM
Sorry I meant lights can be switched on without key in ignition
Post by: nistri on 06 March, 2020, 01:42:57 PM
Yes, correct
Post by: JJC on 06 March, 2020, 03:00:42 PM
Thanks Andrea 🤞 it’s sorted
Post by: lancialulu on 06 March, 2020, 04:35:21 PM
so what was it. Fuse or ignition switch? or lights switch earthing?
Post by: JJC on 07 March, 2020, 08:03:19 AM
It could be a combination but I think it was ignition, I could post some pics
If I knew how to ! I hope to test it properly this weekend.
Post by: HF_Dave on 12 March, 2020, 09:03:43 PM
The same problem I had with my 2000 HF , the ignition switch was the culprit , I replaced the back of the switch with one I had in my spares and there's been no problem since .
Post by: frankxhv773t on 12 March, 2020, 11:08:03 PM
To attach pictures 1) click to reply, 2) click on "additional options" which is in blue to the left and below the main text box, 3) below this click on the "browse" button at the right hand end of the "attach" text box, 4) navigate in your computer to the picture you want, 5) having clicked on the picture you want its' file name will appear in the "file name" box at the bottom of the window where you selected the picture, 6) click on "open" at the bottom of that window, you have now attached a picture and its' file name will show in the "attach" box previously mentioned. The "browse" button to the right will now show "more attachments" so you can go through the routine from clicking on "browse" to attach more pictures. Once all the pictures are attached you can click on "post" in the usual way and you are done. Good luck.
Post by: peteracs on 13 March, 2020, 08:40:21 AM
Just to add to the well written post above, there is a total size limit on photos for each post. You will get an error if the total size is too high. This can easily happen with modern hires cameras as the files they create can be large.
Post by: JJC on 13 March, 2020, 03:51:02 PM
Thanks for that I will move some pics from iPhone to PC and have a go. I’m 99% sure
it was the ignition switch. Currently got the tank out for a re-furb being powder coated
today so will report back next week :)
Post by: Fulviaclassics on 04 April, 2020, 06:00:38 PM
Ignition switch, common nowadays for Fulvias to fail, get one off ebay.it about £75 for a MM with new keys, just unplug the old plug in the new and away you go! or something like that, good luck with the lock bolts you may have to drill them out ;)
Post by: lancialulu on 04 April, 2020, 06:48:04 PM
If you can get a thin blade angle grinder to them to create a slot for a screw driver - a lot less hassle... You might find it easier to take the steering column off and work on the bench...
Post by: nistri on 05 April, 2020, 08:49:30 AM
To remove the ignition switch from any S2 Fulvia, one should disconnect the battery, remove the black plastic surrounds around the steering column (4 long screws), remove the fasteners fixing the ignition lock to the antitheft block, disconnect the multicontact plug, insert the key into the lock and turn it to the "GAR" (garage) position, i.e. first click to the right after inserting the key, remove the key, press with a Philips screwdriver the small side button and the lock pops out. To my (limited) knowledge I have seen faulty ignition locks to be "repaired" with a good squirt of WD-40 or contact cleaner. Andrea
Post by: JJC on 14 April, 2020, 11:12:55 AM
Well Andrea's advice would have been helpful 😁 I cheated with a dremel and cut a couple of slots in the barrel housing, I’ve not taken the car out as much as I had hoped but I’m 99.9 % sure it was the dirty contact in the ignition barrel because the issue has gone away. I will stick some pictures up this week. I’m making use of the lockdown time by rebuilding driveshafts and fitting new CV boots 😁
Regards
John
