Model Technical and Interest => Aprilia, Ardennes and Ardea => Topic started by: John Larkin on 20 October, 2020, 03:06:23 PM
Title: Mystery switch on Aprilia steering column
Post by: John Larkin on 20 October, 2020, 03:06:23 PM
I'm rewiring my 1949 Aprilia berlina from scratch.  There were too many different repairs and bodges just to carry out minor repairs, so I took photos and made notes, and then launched an offensive with wire snips.  I missed noting where the wire from one switch went, and I cannot trace it as many cables were made up of different-coloured wires joined along their length.  The switch looks as it it might be a contemporary after-market device.  It's a lever toggle switch of high quality and has one terminal only.  There are two positions, open and closed.  It completes a circuit through the switch body and the steering column, and so it earths some device.  I suspect that it may be a horn switch.  Does anybody recognise it?    There is logo inside:- CB, and a number:- 928. I've attached two images.
John Larkin.
Title: Re: Mystery switch on Aprilia steering column
Post by: simonandjuliet on 20 October, 2020, 06:39:56 PM
I've seen similar before, but used for dipping lights
I rewired my Cabrio from scratch adding a couple of circuits for modern side/brake lights etc (plus an iPhone charger option as well) - very satisfying
There is a chap in Italy making repro woven wiring that is very nice - takes longer to wire because it's all the same colour , but the end result is great
Post by: tzf60 on 21 October, 2020, 11:02:56 AM
Hi John,
As you've suggested, maybe a horn switch to overcome the delicate original unit that mounts on the steering column? My bakelite unit has already already been repaired.......!!
Is the stalk switch spring-loaded?
Regards,
Post by: John Larkin on 21 October, 2020, 12:59:20 PM
Hi Tim,
The switch is not spring-loaded, so I suppose that makes it easier to give long blasts of the horn to annoy other motorists!
Regards,
John.
Post by: Raahauge on 21 October, 2020, 07:18:05 PM
Quite possibly an aftermarket item which the factory adopted with the Ardea, who's horn button can be turned about 30 degrees to lock it on, saves so much effort!
Post by: fay66 on 22 October, 2020, 09:59:29 AM
Similar mounting to the'Bloster' steering blockers for Fulvia and Flavia, and certainly looks aftermarket fit to me.
8227 8)
Post by: John Larkin on 24 October, 2020, 06:05:35 PM
I've concluded that it is a dip switch.  It earths the coil in the headlamp changeover switch.
