Model Technical and Interest => Aprilia, Ardennes and Ardea => Topic started by: John Larkin on 27 June, 2021, 09:30:05 AM
Title: Rear brake drums
Post by: John Larkin on 27 June, 2021, 09:30:05 AM
A friend with an Aprilia cannot get his rear brake drums off.  He has removed the drive shafts.  I have not done this type of work on my own car, so I'm not able to guide him.
I would appreciate any advice about getting the drums off.
John.
Title: Re: Rear brake drums
Post by: chriswgawne on 27 June, 2021, 09:34:34 AM
If there is any similarity in removal of rear brake drums between Lancia models of that general age, there will be 2 threaded holes opposite each other towards the inner area of the drum which will accept metric bolts ( either 6mm or 8mm i would guess) which will push the drum off its backplate when screwed in. Be careful to do this equally each side.
Hope this helps.
Post by: John Larkin on 27 June, 2021, 09:57:56 AM
Thanks Chris!
John
Post by: Sliding Pillar on 27 June, 2021, 10:10:27 AM
Also check that the handbrake levers on the backplates are fully off, they can stick.
Post by: davidwheeler on 27 June, 2021, 12:58:32 PM
The back plates are not such as would take a lot of thrust I would think.   Moreover, I am not aware of such holes in my brake drums. If the drums rotate freely they should pull off using a big enough (so as to encompass the diameter of the drum) puller.    You may find the pics helpful.
Post by: Raahauge on 27 June, 2021, 07:42:18 PM
Threaded holes in the drums would, I think, only exist where the drum is mounted against a flange such as where the drums are mounted behind wheels.
As long as the drum is free to rotate as mentioned earlier then it is not difficult. There is a threaded nose in the centre of the drum about 35mm diameter to which a puller can be attached. The club may have a puller but if not I have one you can borrow.
If the drum is not free to rotate then it can be a pig as when you try to pull the drum off, the shoes cant over and lock things up. In this case keep turning the drum and gently pull at the same time but it can still be tedious. Call me if you wish. Best of luck.
Mike
Post by: peterblenk on 31 July, 2021, 05:10:02 PM
My rear drums have threaded bosses. A special cylindrical tool Shaped like a tin car, with one end removed)  screws onto these bosses. At the closed end of the tool is a screw that mates with a dimple in the axle end. Wind down this screw, and the drum should come off. Do not use levers on the edge of the drum, as you will only chip the drum and bend the backplate. If you don't have the tool, a machinist can make you one. I regret that I don't know the thread size. Peter
Post by: neil-yaj396 on 01 August, 2021, 07:37:17 AM
I wonder if the Club has this tool for hire? Worth checking with Tim Heath.
Post by: lancialulu on 01 August, 2021, 05:22:56 PM
I believe we have a tool.
Post by: Raahauge on 01 August, 2021, 08:40:23 PM
Be aware that there are two types, some drums have a threaded boss and some have a plain nose with two slots which engage the fingers of a puller.
Mike
