Model Technical and Interest => Aprilia, Ardennes and Ardea => Topic started by: Scarpia on 21 May, 2008, 04:30:49 PM
Title: carbon footprint
Post by: Scarpia on 21 May, 2008, 04:30:49 PM
I just returned from testing the aprilia on its CO2 emissions in a friendly local garage before I go to the MOT next week.With a little adjustment as we tested, it is now producing a miserly 1.5 % emission and the limit to be achieved was 3% or under.This seems rather good for a 61 year old car.How does this compare with moderns , any ideas ?.
It clearly would suggest I have to drive as much as possible to help save the planet....
Title: Re: carbon footprint
Post by: davidwheeler on 24 February, 2009, 09:56:54 AM
An Aprilia, in cpmmon with all PVT cars, does not need to undergo emissions testing.  However, an impressive result suggesting even that your mixture is a little lean.
Post by: fensaddler on 24 February, 2009, 12:10:49 PM
I presume what they were measuring was your CO (carbon monoxide) rather than CO2 - most of your exhaust gases with a modern or an old car would be CO2 or water vapour.  On a modern, CO, NOX (oxides of nitrogen) and hydrocarbon traces (unburnt fuel) should be in fractions of a percent.  However, for an old motor CO readings at the level you suggest, and for any pre cat car, are pretty good.
Post by: Scarpia on 27 February, 2009, 05:18:35 PM
how right you are..in my elation at the better than expected results I started typing before engaging brain...
strangely, in the inverse "lewisiaan" universe I patrol I seemed to write this only a few minutes ago but as clearly evidenced below it was nearly a year ago of your earthly time...Maybe I should have mentioned Carbon 14 instead....
in either case I have strived to use the car more to save the planet as described...
Post by: davidwheeler on 07 March, 2009, 10:10:28 AM
Well, we old car types are often accused of living in a time warp.
