Model Technical and Interest => Dedra, Thema and Delta (2nd series) => Topic started by: GREENYORKIE on 21 May, 2022, 08:57:09 PM
Title: Delta HPE HF indoor car cover
Post by: GREENYORKIE on 21 May, 2022, 08:57:09 PM
Are there any owners out there who know of a source for a cover for the above?
David.
Title: Re: Delta HPE HF indoor car cover
Post by: GialloHPEIan on 22 May, 2022, 11:53:27 PM
Hi David
I've had this cover for about eight years   https://www.ebay.co.uk/itm/281691334213?hash=item41961ca645:g:8gAAAOSwQLJfW89X
My car is outside but this cover is the only tailored one I have ever found. It's a bit of a snug fit as I reckon it was designed for models without the bodykit and flared wheelarches but is well made and besides the cat using the rear corners as a scratching post has stood up very well to our weather. It has a soft fleecy lining that has caused no paint damage. You will need to make sure the mirrors are folded in and the radio aerial is removed before fitting. There are also others listed on eBay if you search "lancia delta 836 car cover" or "lancia delta hpe car cover". Hope this helps
Post by: GREENYORKIE on 23 May, 2022, 08:44:42 AM
Thanks for this Ian, looks promising,will do my research later.
Regards, David.
Post by: GREENYORKIE on 24 May, 2022, 09:03:04 AM
That's an interesting picture on the website, don't recognise the Lancia under the cover! Could you post a couple of pics of your cover Ian to give me an idea of how it fits.
Regards,
David.
Post by: GialloHPEIan on 19 June, 2022, 09:09:22 AM
Hi David
Apologies for the time lapsed to respond to your request for pictures.
As you will see my cover has been ravaged by the weather and a cat that decided the cover made a good scratching post! I was given a new cover for my birthday (non tailored) which is a looser fit and has a strap that goes across under the car to hold it in place on windy days. Not an issue for you for indoor use. Hope this helps.
Regards
Post by: GREENYORKIE on 11 July, 2022, 10:14:38 PM
Thanks for the pics Ian. Seems a good fitting cover.
Cheers,
David.
