Model Technical and Interest => Fulvia => Topic started by: Paul Greenway on 15 November, 2022, 09:55:59 PM
Title: Colour Code for 1600 Cam cover
Post by: Paul Greenway on 15 November, 2022, 09:55:59 PM
Does anyone have the the colour code/paint type for the yellow cam cover. I'd like to get mine repainted so would appreciate some advice, thanks in advance.
Title: Re: Colour Code for 1600 Cam cover
Post by: davidwheeler on 16 November, 2022, 03:24:35 PM
I used a can of Fiat Broom Yellow from Halfords - looks good.   The code seems to vary with the supplier and the Fiat forum seems to feel it is a very difficult colour to match as well and liable to fade.     How fussy are you, mine is fine after 10 years..
Post by: Spider2 on 18 November, 2022, 04:00:28 PM
I need to paint the cam cover on my 1.3S engine which should be crinkle mat black. I think the two "Lancia's" inscribed on the cover need to be plain metal and polished. How is that done? Could be a really fiddly job. Is there a trick to doing it so it looks professional?
Post by: SanRemo78 on 18 November, 2022, 04:29:28 PM
Polish the lettering first, crackle finish the whole cam cover and once its fully cured sand it off with a block?
Post by: Spider2 on 18 November, 2022, 04:41:55 PM
That's one way but the really beautiful examples I have seen have the vertical sides of the lettering polished as well. sanding the top off afterwards would not accomplish that.
Post by: SanRemo78 on 18 November, 2022, 04:53:39 PM
Must have been masked off carefully then? And masking tape removed before the crinkle finish appears?
Post by: davidwheeler on 19 November, 2022, 09:13:34 AM
1300S may have been black crackle but 1600 Sport is definitely yellow.
Post by: Paul Greenway on 19 November, 2022, 07:38:12 PM
Hi David, is there no issue with the Fiat Coupe Broom Yellow when the engine gets hot? I was thinking it may have to be a special paint.
Post by: davidwheeler on 20 November, 2022, 02:07:20 PM
I have not had any problem at all.  Been on there for 10 years now.
Post by: jus on 21 November, 2022, 07:30:28 PM
Not wanting to hijack the thread, but while we're talking paint - does anyone know what colour the block should be painted on an HF?
Was it the same for S1 and 2?
Post by: GlynW on 11 December, 2022, 10:35:34 PM
I have used Ford Signal Yellow (Halfords spray can) on mine.  No problem with heat degradation or otherwise and it still looked good after 16 years (when the whole car was repainted).  Might be worth comparing with the Fiat colour.
