Model Technical and Interest => Flaminia => Topic started by: a1city on 16 April, 2023, 03:05:19 PM
Title: Ballast resistor
Post by: a1city on 16 April, 2023, 03:05:19 PM
Hi all, on my 2.5 3b PF coupe we are suspicious of the magneti marrelli ballast resistor. Problems starting once the engine is warm in the workshop? And looking for other peoples experience re the ballast resistor and to find possible alternatives and are they essential?.? Thanks Dave
Title: Re: Ballast resistor
Post by: Mikenoangelo on 17 April, 2023, 07:09:41 AM
The ballast resister is used with a 9v coil and is in the circuit when the engine is running but by passed  when the starter is used, applying the full 12v and temporarily boosting the coil output. If you change to a 12v coil you could disconnect the resister but perhaps just getting a new resister might be the answer.
Mike
Post by: lancialulu on 17 April, 2023, 07:26:34 AM
I am not sure the Italians bypassed the ballast on start up. That was a Ford trick to start their over square engines in cold weather.... Could be wrong though.
Post by: chriswgawne on 17 April, 2023, 08:50:50 AM
I am not aware that Lancia ever bypassed the ballast resistor on startup.
