Model Technical and Interest => Flavia => Topic started by: shignett on 11 September, 2023, 06:22:56 PM
Title: Flavia 1800 Kugelfischer Idle Advice
Post by: shignett on 11 September, 2023, 06:22:56 PM
Recent purchased a mint Flavia Berlina 1800 and have been trying to set up the Kugelfischer.
Fuel enrichment, wax gizmo is working fine (remarkably) as the water heats up.
Car originally wanting to stall at <400rpm when warm - no adjustment possible on the (top) idle screw. So, cleaned out the gunk in the bypass port with wife's expensive makeup brushes, (ideal for that task incidentally....) Got shouted at quite a bit, but also got rid of the "sludge" buildup
Idle adjustment now excellent.
However, to get the warm idle speed about right (~900 rpm) , the cold idle speed on startup ends up >1500rpm.
If I dial that back with idle screw, the hot running is too slow and stalls.
How to set the cold and hot speeds with out taking a PHD in Kugelfischer set up?
Is there a simple cold idle adjustment on the enrichment or will western civilization end if I start dabbling?
Omicron suggested leaving well alone, but the high rpms when cold are embarrassing and frightening small children
Anyone?
Stuart
Title: Re: Flavia 1800 Kugelfischer Idle Advice
Post by: RobMc on 04 November, 2023, 07:36:14 PM
Hello Stuart,
I reckon your problem could be the set up of your auto enriching device.
I don't have a PHD in Kugelfischer set up but I have stripped and rebuilt the auto enriching device on my Flavia 1800 injection. I didn't have the special tools that the manual mentions when it came to installing this back on the engine and setting it up, so there was a fair bit of trial and error. During this, one thing I discovered was that moving the enriching device lever up and down by hand, when the engine was cold, altered the idle speed. You can't really move the lever by hand after setting the device up as when the engine is cold, the lever is held in the raised position by the adjusting nut on the push rod - if that makes sense.
I know you said it's working fine but maybe it is not set up quite right and this could account for the wildly different idle speeds. You've obviously noted when your engine is hot the push rod of the auto enriching device extends. Have you noticed if it extends enough to allow the lever of the enriching device to lower all the way down, effectively turning it off. At this point, the gap between the adjusting nut and the lever should be around 3mm at 80 degrees C. If the gap is noticeably more or less than this when the engine is hot, then the adjusting nut/lever will not be returning to the correct position when the engine is cold and this could account for the idle speed being wrong when cold.
God knows if this is making any sense...
So, I would get the engine up to full operating temp, with the idle at 900 rpm ish, and then check the gap between the adjusting nut and the lever. If it's not around 3 mm then you could undo the lock nut and alter the adjusting nut until the gap is around 3mm. Hopefully when the engine then cools, the enriching lever will be in a new position that produces a more acceptable cold idle speed.
This is how I set mine up and the cold idle speed is only a little faster than when the engine is hot.
I will try and post a picture to help with this.
Cheers, Rob
Post by: RobMc on 04 November, 2023, 07:44:17 PM
Hello again, Hopefully these images will help with my previous reply. Obviously no need to do the test if the suggested set up solves things.
Cheers, Rob
Post by: GG on 05 November, 2023, 08:14:37 PM
We have found cold start on the KF system has a high idle - takes it time to settle down. Also if its sat for a while, it will (in the cold) be very lumpy - possibly attributable to thick oil on the pear-shaped cam and the injector activation (deep inside the pump). Takes this a while to warm up and for things to settle into place.
Post by: shignett on 01 February, 2024, 03:30:47 PM
Many thanks for all for the advice.
The car has been away getting, what can only be described as rusty inner front sills sorted out.
Yes, even on a car that looked this good, jacking a corner up can reveal issues.
https://www.classiccarshop.co.uk/home/cars/classic-sold/car/view/9/811
Back to the Kugelfischer hot/cold idle issue very shortly.
Ill let you know if we improve the disparity between the hot and cold idle speeds.
