Model Technical and Interest => Aprilia, Ardennes and Ardea => Topic started by: peterblenk on 11 January, 2024, 11:18:38 AM
Title: Aprilia Boot seal
Post by: peterblenk on 11 January, 2024, 11:18:38 AM
My Aprilia boot leaks copiously. I did try fitting the seal that Cigognani sells (I fitted it to the bodywork, not to the boot lid, which may have been an error) but I then found that I could not close the boot. Some say that the Aprilia boot did not have a rubber seal originally, as water was supposed to run down the channel in the bodywork and out the bottom, but I find that this does not work. I have looked at many Aprilias but have not found the answer. Does anyone have a solution? Peter Blenk
Title: Re: Aprilia Boot seal
Post by: Sebastien on 13 January, 2024, 09:34:22 PM
Have you seen this?
https://www.registroaprilia.it/guarnizioni-per-il-baule-aprilia/
