Model Technical and Interest => Fulvia => Topic started by: julian67 on 20 February, 2024, 05:03:26 PM
Title: S1 Fuvia coupe front / rear disc removal procedure + tools needed
Post by: julian67 on 20 February, 2024, 05:03:26 PM
Due to my car not been driven for a long time, both front / rear brake discs are rusty.
I tried sand paper but the discs are still rusty.
What is the procedure + tools needed to remove front / rear discs?
Any advice most welcomed.
Title: Re: S1 Fuvia coupe front / rear disc removal procedure + tools needed
Post by: nistri on 20 February, 2024, 05:08:37 PM
After removing the calipers, you will need the Lancia special tools that can be hired through the LMC.
Post by: davidwheeler on 21 February, 2024, 10:53:00 PM
You might manage on the car with an angle grinder fitted with a wire cup brush though this would not deal with the rear handbrake drums..
Post by: Simon B on 22 February, 2024, 08:29:10 AM
If you don’t know how long it is since it has all been apart I would give some thought to there being asbestos pads or shoes. And for the same reason cautious with the angle grinder even having washed everything down.
Post by: julian67 on 22 February, 2024, 02:15:36 PM
Thank you for your helpful advice.
Will see if the old pads can clean up the rust on the calipers. If not, I'll have to remove them.
Post by: fay66 on 23 February, 2024, 09:58:51 AM
No handbrake drum on series 1, separate set of  handbrake pads with mechanical mechanism.
Although the large slot head adjustment screw might be a problem if seized!
8227 8)
