Model Technical and Interest => Fulvia => Topic started by: Keithver on 29 February, 2024, 03:16:44 PM
Title: fuel additives
Post by: Keithver on 29 February, 2024, 03:16:44 PM
I am running my S2 1,3 on normal (in ZA) 95 octane fuel. I have just replaced the plugs (champion N9Y) and the engine still stutters at around 2000 RPM
A carb specialist has advised me to add about 200ml of diesel to a full tank.
He reasoned that the fuel today (without the lead) is less able to lubricate properly and the diesel in the fuel should lubricate better.
My understanding is, that adding diesel to the tank will slightly reduce the octane rating.
As i said, I run 95 octane which is one point lower than the recommended (handbook) 96 octane.
Is this a good idea or not?
I heard somewhere else that one could add kerosene (paraffin) alternatively, with the same results.
The same guy said that I should run a hotter plug and suggested the Bosch WR7DC+ for our warmer climate.
Should I worry about additives or not?
Any thoughts would be appreciated
Title: Re: fuel additives
Post by: lancialulu on 29 February, 2024, 04:52:30 PM
Stuttering at c 2000 is caused by poor valve timing in my experience. I would not add diesel.... Octane values are to guide for preignition conditions. Does your Fulvia engine pink under load (at 2000-3000 rpm)?
Post by: neil-yaj396 on 01 March, 2024, 08:18:03 AM
My Beta used to run fine on the old 95 octane E5, but since it was upped to E10 it hasn't run well, especially on hot days. I've always added the odd glug of Millers VSPe and have now moved to Super E5. Diesel and Kerosene are definitely not suitable additives. The latter would actually reduce both the octane and the lubricity of the petrol. It can cause overheating and is in any case illegal as you are technically 'extending' the fuel.
Unlikely, but HMRC could seize your car if they found kerosene in your fuel.
Post by: nistri on 01 March, 2024, 08:20:36 AM
The current method to measure octane rating is different from the past one, hence 95 is the old 96.
Post by: Keithver on 01 March, 2024, 08:29:23 AM
I'm pretty sure that the timing is correct. All three timing marks line up perfectly.
I haven't noticed any pinking. The problem seems worse at low revs in low gears. She runs better as the revs increase
Post by: lancialulu on 01 March, 2024, 08:48:09 AM
The "timing marks" are to initially set the cams so the valves do not touch the piston when turning over the engine totime the cams..... I use a crankshaft protractor (download and print one) a dial gauge on inlet /exhaust #1 valves set to a "setting" clearance of .4mm. Depending on the cam you look for the opening and closing position of the valves. Depending on the camshaft (I assume 303) you calculate the MOP (max opening position) from these measurements and set the cam to 109 ATDC for inlet and 109 BTDC for exhaust (303 cam - others may be different). I have a car that hesitated badly and after trying everything looked at the cam timing and it was 20 retarded on the inlet....
Post by: davidwheeler on 01 March, 2024, 09:51:29 PM
I would have thought that 95 octane is a bit low.  I run my SII 1600 on 99 octane from Sainsbury's.   (or Tesco)  Worth a try perhaps, especially as it is E5.
Post by: Keithver on 02 March, 2024, 05:52:57 PM
Tim Thanks - It is a 303 engine. I presume the cams are standard. I am notoriously bad at understanding things. I need to draw them before I might understand. The photo below shows my crank protractor. With help from the workshop manual I note that your 109deg bisects the obtuse angels of opening and closing angles given in the manual. The first bit of sense!
I have written a description of your process below. Would you be kind enough to let me know if it is correct before I climb under the bonnet, Please
Use a crankshaft protractor (download and print one).  Set the gap to 0.4mm for inlet and exhaust valves of #1. (where does the 0,4mm come from)
Look for the opening and closing position of the valves using a dial gauge.
Check when inlet valve #1 begins to open and set the dial gauge to zero.
When it closes completely, note the gauge measurement.
Calculate the MOP (max opening position) from these measurements (halfway between the two).
Turn the crank so that the inlet cam is at MOP according to the dial gauge calculation. Remove the inlet Vernier pin and turn the crank so that the protractor reads 109 ATDC for inlet valve #1.
Re-insert the Vernier pin.
Repeat the same process for the exhaust cam, but so that the exhaust cam is set to 109 BTDC for exhaust.
As I say, it takes me a while to understand these, for me, complicated things
Unfortunately, Here in ZA, we only get 95 octane at the coast. Its only 93 upcountry. 99 is not available
Post by: nistri on 02 March, 2024, 07:07:02 PM
For the 303 engine the maximum valve lift is 2.2 mm. Harry used to sell a custom made feeler gauge of 2.2 mm to set the camshaft timing.
Post by: lancialulu on 03 March, 2024, 07:42:08 AM
Hi Keith
Sent you a pm
Post by: jimbo64 on 04 March, 2024, 06:19:31 PM
I use this online may help these are your details you supplied
Post by: Jaydub on 06 March, 2024, 06:44:11 PM
All good advice on the cam timing, but no use at all until you have set a true TDC, because the manufacturing tolerances mean the standard TDC marks could be quite a few degrees out, and therefore so will your cam timing!
Look at BURTON PERFORMANCE CENTRE website. Top right of their opening page, it says "tuning Guides". Click on that and then click on "Cam timing" It will explain how to get a true TDC.  Once you have that you can then set cam timing, but not before.
Good Luck.
Post by: lancialulu on 06 March, 2024, 10:18:20 PM
Good Luck.
also if someone has changed the flywheel ……
Post by: Keithver on 07 March, 2024, 02:42:02 PM
Thanks Jim for the very useful adjustable degree wheel. What a great tool.
Thanks for the TDC tip John. I checked and the flywheel mark lines up almost exactly. The marks are maybe the width of the stamped lines out.
Tim, I set the cams up with your MOP method. I see why you say, check, check and check again.  Both cams look as if they were out by about 5 or 6 degrees.
 As you can see from the photos, at TDC the inlet cam mark (photo 1) is slight past the mark now and the outlet slightly more than that.
The engine starts and I took it for a very short run. All seems fine. I will take it for a good run on the weekend to test it properly.
Thanks again for all the help and information
Post by: jimbo64 on 07 March, 2024, 08:24:14 PM
This is where mine ended up slightly advanced  inlet,  spot on exhaust
Post by: Keithver on 10 March, 2024, 01:14:33 PM
Tim. Apologies up front. When i took it for a good run, it felt as if I had lost half my throttle.
I had visions of re-setting the cams to stock initial position and keeping quiet.
In fact, that's exactly what had happened. I HAD lost half my throttle.
(Photo 1) shows how the "stop clip" at the engine bay firewall had pulled back the black plastic coating and pulled the steel inner through the firewall.
The clips where what was on the old cable when I got the car. I simply reused them. Is there something that goes onto the cable housing to stop it pulling through, I don't see anything in the parts book.
I made a stopped nipple to hold the casing in place and stop it being pulled through in photo 2.
I took her out for another run. Chalk and cheese.  She revs beautifully and pulls wonderfully.
Unfortunately, I still have the stutter. I'm thinking it is probably the carbs
