Title: A couple of carb questions. Post by: coltom on 03 July, 2024, 11:14:28 AM Am I right in thinkng the series 1 Rallye (818330) came with CH32 Solexes? I have the chance to buy a pair of used Solex CH35PHH which were taken from a Fulvia but the seller doesn't which year, model, etc. I'd like to rebuild these as a project. Will they fit my Rallye with appropriate jets, etc? One is stamped PHH19 & the other PHH16.
Also, I've found a seller in the US of new old stock Dellorto DHLB 32 (no jets, spindles, etc). I believe Dellorto DHLB 35s were the optional fit to the Fulvia. Would the 32s work and be a direct fit to the manifold and what's the difference between the 32s and 35s? Thanks, Colin Title: Re: A couple of carb questions. Post by: nistri on 03 July, 2024, 12:08:33 PM Your 818.330 will work fine with 35 mm carbs and will perform poorly with any 32 mm carb.
