Title: Spax shocks info please Post by: lancialulu on 17 May, 2009, 04:11:33 PM Does anyone have any old Spax data.
I bought (admitedly off ebay) some NOS Spax shock absorbers for my Fulvia. They were stamped (and also the box was printed with) 434 which is a Spax Fulvia part number as far as I can see. However, the closed length (370mm) from top mounting mid point to c/l bottom trunnion is longer than the fully open length of Fulvia coupe shocks (360mm). The Open length is c 610mm (!). I reckon they were for a lorry or something. They have same mountings as fulvia fronts. I just want to identify them and put them back onto Ebay. Thanks Tim Title: Re: Spax shocks info please Post by: ncundy on 17 May, 2009, 05:21:40 PM I put this up about two years ago in my restoration thread when I was deciding on which way to go, as there were reports of a similar issue on Viva Lancia:
"A set of Spax shock absorbers finished it off. It is worth knowing that the part numbers listed by Spax would seem to be incorrect, the difference is in the open length: G434 Front 357 (as listed) G3312 Front 332 (as required) G677 Rear 441 (as listed) G3318 Rear 426 (as required) See this thread http://www.viva-lancia.com/lancia_fora/read.php?10,5652,5652#msg-5652 " I called Spax and confirmed the situation at the time and found them very helpful. There are a couple of other threads on Viva Lancia as well, just search for Spax. Hope that helps Neil Title: Re: Spax shocks info please Post by: ncundy on 18 May, 2009, 07:24:29 AM Spax do a range of "self specify" custom dampers for classic cars. The longest stroke is 240mm as yours. Part number would start K95.......
http://www.spax.co.uk/selector_html.php Might be difficult to find exactly what it was intended for though. Title: Re: Spax shocks info please Post by: ColinMarr on 19 May, 2009, 08:51:00 PM Here are two links to websites that are relevant:
- the first is to the Flavia / 2000 Consortium page on shock absorbers. I guess this is written by Peter Longhurst who doesn’t use this Forum, but is still out there a helping do good thing for Flavia and Fulvia: http://www.flavia2000consortium.org.uk/Technical/Shock_absorbers.html - the second is a link to AVO, who still offer dampers for Fulvia and Flavia. http://www.avouk.com/ Look at their Roadsport range. Not that I need them now, but I could be tempted to use AVO in preference to other options. Does anybody have experience of AVO? Colin Title: Re: Spax shocks info please Post by: fay66 on 19 May, 2009, 11:36:02 PM I like the sound of AVO coil overs for the rear, and as suggested by Peter Longhurst to assist rear springs that may have lost a bit of the tempering, unfortunately not available for Lancia.
As for De Carbon shock absorbers, these are still available and are advertised http://www.viva-lancia.com/huib/coll/de-carbon.htm for Fulvia at E80 each plus P+P. Brian 8227 8) Title: Re: Spax shocks info please Post by: Neil Lewis on 20 May, 2009, 07:12:03 PM For what it's worth, the Spax factory is on the same industrial estate as my company Stack and, a couple of years ago, I was looking for a pair of rear shocks for Richard Fisher's Series 1? Fulvia Zagato (the one with the seperate spare wheel door). I dopped off a Koni damper which had been fitted to Richard's car and this is what the Technical Director said :-
"I've had a chance to look at the dampers The Spax G3318 is the best match with the offset loop. The extended length is 422. Your sample has an extended length of 432. Also the damper top sleeve is slighly slighly longer on the spax unit (+3mm). If you want these dampers fine the price is 57.41 each + vat If you require a custom build it will be 65.99 each" In a later email, Tony said he'd recorded the dimensions in his "book" so presumably they collect lots of information for later and/or custom builds. We didn't buy the shocks because Richard had to scrap his Zagato soon after my enquiry. There is a comprehensive parts list on Spax's web-site and the part numbers for various Lancia dampers are on there. As I recall from a conversation with Spax, the front dampers will fit both Series 1 and 2 and both Coupe and Zagato. Hope that helps Neil Title: Re: Spax shocks info please Post by: lancialulu on 20 May, 2009, 09:53:03 PM Hi all
Having set the challenge to try to identify these mysterious Spax shocks, the only thing I can say is that they were probably custom made to the largest custom size in Spax's range as Neil thought. It is unfortunate that cataloguing of different vehicles dampers do not give length specs. However this thread will be useful for qualifying what is required for fulvias spax shocks. I have posted the shocks on ebay for 99p to clear my shelves.... Tim |
