Model Technical and Interest => Flavia => Topic started by: Angle Grinder on 15 July, 2009, 04:38:29 PM
Title: Gearbox Oils - recommendations
Post by: Angle Grinder on 15 July, 2009, 04:38:29 PM
Has anyone got any opinions or guidance on the best type of Gearbox Oil for a 1967 Flavia 1800?
I've found this Millers oil that sounds like it would do the job!?
Classic Gear Oil 80w90 - GL4
DESCRIPTION:
* EP Transmission oil to APIGL4 for classic transmissions
* High quality solvent refined mineral base stocks with performance additives.
http://www.millersoils.net/1_Millers_frame_CLASSIC.htm (http://www.millersoils.net/1_Millers_frame_CLASSIC.htm)
And now a dumb question... it looks like there is a filler plug on the O/S side of the gearbox, I assume that topping up until this overflows (on level gound) will equate to the correct Max oil level... yeah?
Title: Re: Gearbox Oils - recommendations
Post by: Sliding Pillar on 15 July, 2009, 05:21:08 PM
If my memory serves me correctly there is a dipstick on the top nearside of both Flavia and Fulvia gearboxes.
Post by: fay66 on 15 July, 2009, 05:27:06 PM
Certainly on fulvia,
 just behind the bell housing with graduated levels marked on it.
8227 8)
Post by: ColinMarr on 15 July, 2009, 08:47:38 PM
For my Fulvia five-speed box I have used the Fiat/Selenia synthetic oil that they specify for all the modern Fiat Alfa boxes. It’s marked TUTELA ZC75/80 - I had to pay £7.48 (trade) + VAT a litre a year ago at my local Fiat agent. It pours like water! I doubt you will find better. I am sure this would be good for a Flavia too.
PS. I was confused at first by the gearbox dipstick, the head of which looks like a black plastic cotton-reel!
Colin
Post by: Angle Grinder on 16 July, 2009, 10:00:14 AM
Thanks for all the tips!
Its so hard to see anything on a Flavia Gearbox and I am quite literally "fumbling in the dark" as I learn my way around the car.
I haven't been able to find any references to the oil capacity of the Gearbox / Diff. Does a standard 5 litre can cover it, or is it like my Thema V6 which always manages to just exceed every standard volume of packaging for automotive consumables!?  :P
Post by: fay66 on 16 July, 2009, 11:04:18 AM
Hi Mike,Just remembered I'd got this, hope it helps
8227 8)
