Model Technical and Interest => Fulvia => Topic started by: fay66 on 31 July, 2010, 10:43:43 PM
Title: Fulvia Series 2/3 Alloy Wheel Bolts
Post by: fay66 on 31 July, 2010, 10:43:43 PM
A friend in France has asked a quetion to which I don't know the answer, can anyone help please.
8227 8)
Hoping you can help me with the following. Are the wheel bolts fitted to Series 2 and 3 Coupés the same as fitted to the Saloons? The reason I ask is that I have been sent a set of 16 Campagnolo bolts,supposedly for my coupé and they are totally wrong in every respect. They are brand new and are a work of art,even with the C in the head.They came in a Campagnolo box marked 7350736.I have contacted various people to see if there is a Campagnolo catalogue but have drawn a blank .
> Any help you can offer would be greatly appreciated.
> Kind Regards
> Tim
Title: Re: Fulvia Series 2/3 Alloy Wheel Bolts
Post by: ncundy on 01 August, 2010, 06:35:11 AM
They're different part numbers if that helps, what the physical difference is I don't know?
Neil
Post by: lancialulu on 01 August, 2010, 06:57:11 AM
The normal Lancia bolts with rounded shoulders are good IMO for both steel and Chromadora alloy wheels. I would have thought campagnola bolts were to same physical spec on length/ thread/ shoulder.
Post by: fay66 on 01 August, 2010, 09:50:51 AM
Neil
Neil,
that beggars the question do you have the correct part number for the Campagnola bolts?
8227 8)
Post by: fay66 on 01 August, 2010, 09:52:13 AM
Thanks Tim, I'll pass it on, does anyone have a campagnola parts book?
8227 8)
Post by: fay66 on 02 August, 2010, 01:17:53 PM
Neil
Message from Tim,
I'm still trying to reduce the size of the photos that are huge, unfortunately my Photoshop elements 2 has gone on the blink at present.
8227 8)
Dimensions on the bolt.Measured with ruler so only approx.Hopefully photo's will help.
Overall Length   64mm
Length Of Thread  21mm
Across Flat Of Head  18mm
Across Thread   10mm
Photos can be found http://www.flickr.com/photos/49840642@N06/?saved=1
