Title: high oil pressure Post by: Richard Fridd on 13 October, 2010, 06:03:08 PM could someone remind me of the pressure at which the oil pressure relief starts to open on a 1300 fulvia.i have 75psi in my mind but my cars mecanical guage is reading higher as is the standard guage even at 3000 rpm.i will inspect the valve before further use.i have 20/50 oil so i should get something thinner for gentle use in cool weather.i did read that oil post recently regarding start up temps and suitable oils with interest although i have used 20/50 in the past with no probs touch wood.advice welcome on that relief valve.at least it is accessable.best regards richard
Title: Re: high oil pressure Post by: lancialulu on 13 October, 2010, 07:50:28 PM Richard
70 psi is I think about right but if oil is cold then you will not release the excess through the relief valve. Have you measured when "hot"?? Tim Title: Re: high oil pressure Post by: Richard Fridd on 14 October, 2010, 04:48:05 PM thanks Tim,i have checked the valve which seems ok.as i have a super efficient rad i will try blanking it partially now that the cooler weather is here.best regards richard
Title: Re: high oil pressure Post by: lancialulu on 14 October, 2010, 05:26:34 PM Oil rad?? This should also be thermostatically controlled. If water Rad are you saying you are not getting the oil hot. I would find that odd. My oil pressure goes to normal before full operating temperature as per my oil temp gauge. Generally with oil hot even a tight/new engine will still drop presure on a fulvia below 2000rpm.
Tim Title: Re: high oil pressure Post by: Richard Fridd on 18 October, 2010, 04:11:12 PM i have tried some cardboard infront of the uprated water radiator which has got the water to 160F and the oil pressure is between 20-70 psi.[no oil cooler fitted]and the engine seems to be running more happily now.thanks richard
Title: Re: high oil pressure Post by: ncundy on 18 October, 2010, 05:07:01 PM This is what the Italians used during winter:
http://cgi.ebay.it/COPRIRADIATORE-LANCIA-FULVIA-FINO-AL-1969-/280417651097?pt=Ricambi_automobili&hash=item414a31c999#ht_2195wt_905 I think you can get them for S2's as well. Title: Re: high oil pressure Post by: fay66 on 19 October, 2010, 12:30:52 AM This is what the Italians used during winter: The one for my 2c came from Martin Willums in the Netherlands, he also had them for series 2 Berlina, in Holland they are known as "Bras". ::)http://cgi.ebay.it/COPRIRADIATORE-LANCIA-FULVIA-FINO-AL-1969-/280417651097?pt=Ricambi_automobili&hash=item414a31c999#ht_2195wt_905 I think you can get them for S2's as well. Brian 8227 8) Title: Re: high oil pressure Post by: rogerelias on 19 October, 2010, 05:25:28 PM With such a flat front, why call it a bra ???
Title: Re: high oil pressure Post by: DavidLaver on 20 October, 2010, 09:02:18 AM Why in particular the open area top right? David Title: Re: high oil pressure Post by: fay66 on 20 October, 2010, 09:26:20 AM Why in particular the open area top right? David David, the "Air Conditioner" intake, Brian Title: Re: high oil pressure Post by: fay66 on 20 October, 2010, 09:28:47 AM With such a flat front, why call it a bra ??? Roger,Flat chested women still wear bra's so why shouldn't "Fay" as she's a lady :D Brian 8227 8) Title: Re: high oil pressure Post by: Richard Fridd on 20 October, 2010, 09:31:22 AM that is the where the fresh air intake is situated to supply the 'airconditioning' for the cabin.until last week my sedan had a similar fresh air solution but nearer the drivers feet.ok now thanks to some MIG work
Title: Re: high oil pressure Post by: fay66 on 20 October, 2010, 09:35:01 AM that is the where the fresh air intake is situated to supply the 'airconditioning' for the cabin.until last week my sedan had a similar fresh air solution but nearer the drivers feet.ok now thanks to some MIG work Richard, pleased to hear the work is progressing :D Brian 8227 8) Title: Re: high oil pressure Post by: Richard Fridd on 23 October, 2010, 01:32:50 PM thank you Brian,next job is to replace the front wings as i have had the good fortune of collecting a brand new pair this morning complete with inner wheelarches [in factory primer with original sticky labels still attached and with 'Gerrish' written in marker pen]a lovely find!best regards richard
Title: secondhand white pvc bra Post by: Richard Fridd on 03 November, 2010, 07:04:19 PM on the subject of the 'bra' the previous owner has kindly offered me a second hand one in white pvc for my s2 sedan which he has surplus to requirement.best regards richard
Title: Re: high oil pressure Post by: fay66 on 04 November, 2010, 12:37:08 AM Richard,
A Lancia Lady in a white Bra, how dignified :D Brian 8227 8) |
