Model Technical and Interest => Fulvia => Topic started by: ah_sprite on 07 June, 2011, 03:13:42 PM
Title: Suspension bushes
Post by: ah_sprite on 07 June, 2011, 03:13:42 PM
Hi all
A question on suspension bushes.
My car's been for a pre-MOT check and has come back with the following issues:
Front ARB bushes
Bottom arm inner bushes
Rear ARB bushes.
Just called omicron, and for all of those it's going to set me back almost £300, which I simply do not have to spend. Are there any other options out there?
Richard
Title: Re: Suspension bushes
Post by: Richard Fridd on 07 June, 2011, 04:53:26 PM
hi Richard ,i have in my auto jumble stuff-front ARB bushes inner machined from ally[the ones which bolt to the subframe]+three new lower arm bushes in neoprene +one used lower arm bush in neoprene[the reason this has been 'used' is that i had trouble pressing it in so found it easier to get another one out of the box.all of these can be seen in my sedan thread and are beautiful.75 pounds inc uk p+p.if you need the outer front ARB bushes you could put a sleeve on the bar ends if funds are tight.best regards richard
Post by: ah_sprite on 08 June, 2011, 10:29:45 AM
Sent you an email last night!
Does anyone else have the remaining bushes hanging around anywhere?
Many thanks
Richard
Post by: TVR810 on 08 June, 2011, 12:39:56 PM
Have you thought about Poly Bushes, I fitted Superflex to a Daimler SP250.They do not specifically list the Fulvia but are worth speaking to!
Paul
Post by: Richard Fridd on 08 June, 2011, 03:47:49 PM
hi Richard,i dont have an e mail[which works].please try a PM if poss.best regards richard 07957292127
