Model Technical and Interest => Fulvia => Topic started by: davidwheeler on 14 August, 2012, 08:33:32 PM
Title: Fulvia ignition timing graphs.
Post by: davidwheeler on 14 August, 2012, 08:33:32 PM
I recently refitted the optoelectronic ignition system that A N Other had fitted to the Sport so that I got four good sparks instead of two and thus had to re-time the ignition.   I did this manually according to the handbook but I always prefer to use a timing light strobe.  At tickover this is very difficult but the book only gives static timing.  I looked online and found the accompanying graphs, engaged my timing adjustable strobe and found I was only about 10degrees out.  Now corrected!  Thought others may make use  of this graph.
Title: Re: Fulvia ignition timing graphs.
Post by: davidwheeler on 14 August, 2012, 08:35:36 PM
Beware, the x axis of the graph starts at the fixed advance not at tdc!
