Title: Rear hub nuts Post by: phil-m on 08 November, 2013, 04:58:41 PM I appear to have 2 types of hub nuts. The only difference appears to only concern the castellations, one type has thin walled high castellations whilst the other has lower more robust looking castellations. Any thoughts?
Title: Re: Rear hub nuts Post by: Richard Fridd on 08 November, 2013, 05:23:12 PM Is this the tool for one of those nuts?
Title: Re: Rear hub nuts Post by: phil-m on 08 November, 2013, 05:38:53 PM Could be, question is can either type be used on an S2?
Title: Re: Rear hub nuts Post by: Richard Fridd on 08 November, 2013, 05:57:34 PM I think it depends upon the diameter of the wheel centres.(Holes)
Title: Re: Rear hub nuts Post by: phil-m on 08 November, 2013, 10:03:36 PM Could be, but you would not have different nuts for types of wheel? Is the lower profile one a Series 1 nut perhaps? My S2 parts list only has the taller, less robust type listed.
Title: Re: Rear hub nuts Post by: davidwheeler on 10 November, 2013, 12:07:31 PM My S2 looks like the one on the left.
Title: Re: Rear hub nuts Post by: lancialulu on 10 November, 2013, 03:39:05 PM Think the one on the right may be fore the front wheel.
Title: Re: Rear hub nuts Post by: phil-m on 10 November, 2013, 04:28:56 PM The front nut has similar castellations but is shallower with a shoulder on the bottom to clamp up the bearing. I think I have S1 & S2 nuts here, question is, will the S1 (if that's what it is) fit an S2? Thread is the same.
Title: Re: Rear hub nuts Post by: roddy on 10 November, 2013, 06:08:09 PM Hello Phil
I think you have an S1 and an S1.5. The 1.5 series still requires a 6 lug spanner, but is of lesses diameter to fit through small centre of the S2 hub. If you have a S2 nut with the 3 lugs, check its diameter against the S1.5 - should match. Regards - Roddy Title: Re: Rear hub nuts Post by: phil-m on 10 November, 2013, 10:13:15 PM Thanks Roddy,
Makes sense, I will check. do you know if they are all interchangeable then? or at least can S1 & S1.5 fit and S2? Title: Re: Rear hub nuts Post by: Richard Fridd on 11 November, 2013, 07:37:44 AM I think it depends upon the diameter of the wheel centres.(Holes) Perhaps I should have said hub centresTitle: Re: Rear hub nuts Post by: roddy on 11 November, 2013, 07:53:34 PM Hello Phil
I think the simple answer is 'no'. They will both screw into the hub to retain the bearing, however :- if you intend to use a S1 nut to screw onto the stub axle to retain the hub, it will only go through the centre of the larger diameter of the S1 lock-ring, not the S2. An S2 nut (3 lug) (or the S1.5 6 lug) will go through both. But, the final matter to consider is the wheel being fitted onto the hub. The centre hole of an S1 wheel is larger to locate over the greater diameter of the S1 castellations, whereas an S2 wheel will not locate and fit over the S1 lock-ring, just the S2 size lock-ring. (S2 Cromodoras can have the inner centre face machined out to locate over the S1 castellations of an S1 car). Hope of some help? Regards - Roddy |
