Title: Inition Switch Failure Post by: Peter W on 05 February, 2014, 10:57:54 PM Does anyone have experience of dismantling a Beta ignition switch? I drove my VX coupe home the other evening, backed it into the garage & switched off. I then realised that the car was not in the right position so attempted to restart. The starter motor worked but the engine would not fire up & I realised that none of the other electrics were energised. Have checked the system through & found that the ignition switch is faulty. Haynes manual says remove bolt that holds the switch to the steering lock but there is no bolt just what appears to be a spring dowel holding the switch cover on to the body. I cannot extract it and am hesitant to drive it further in to release the cover.
Peter Title: Re: Inition Switch Failure Post by: SanRemo78 on 05 February, 2014, 11:16:10 PM Hi Peter, the Beta, like many Fiats of the era have shear bolts holding the two halves of the lock assembly to the column, it's a design to stop thieves simply using a spanner to unbolt the whole thing effectively removing the steering lock and allowing a simple bypass of the electrics.
To remove the assembly you'll need a centre punch and a drill. Put a plastic sheet over the carpet to stop the swarf getting in, remove the shroud to expose the remains of the shear bolts, punch the centre of both and drill out (I think it's a 10mm drill). Once you've repaired/replaced the lock the assembly can be put back with a couple of normal allen key type bolts. I've always found that drilling the remains of the old bolt heads out leaves enough of a stub that the remainder of the bolt can be removed with a pair of mole grips. Cheers Guy Title: Re: Inition Switch Failure Post by: neil-yaj396 on 06 February, 2014, 05:14:04 PM I'm not sure about the VX, but isn't there also a relay downstream from the ignition switch that can fail? If I disconnect my battery for any period I get the same symptoms until the relay 'energises'.
However the ignition switch on my ie (more akin to your VX) failed in exactly the same manner many years ago and did have to be replaced. That was in the days when you could order one from any spares factor! Title: Re: Inition Switch Failure Post by: Peter W on 07 February, 2014, 03:44:30 PM The switch is the problem as there is no continuity through it when it is turned on.
When I first looked at it I wondered if I could drill out the shear bolts so am pleased to read that this is possible. However, closer inspection suggests that the electrical switch must be dismantled from the outer, key, end of the assembly by removing the 'tin' cover. This cover is held in place by what appears to be a hollow spring dowel. The only way to release the cover seems to be to drive the dowel further into the casing but I am concerned that I may damage the switch internals in doing so. Title: Re: Inition Switch Failure Post by: fay66 on 08 February, 2014, 12:37:29 AM The switch is the problem as there is no continuity through it when it is turned on. Peter,When I first looked at it I wondered if I could drill out the shear bolts so am pleased to read that this is possible. However, closer inspection suggests that the electrical switch must be dismantled from the outer, key, end of the assembly by removing the 'tin' cover. This cover is held in place by what appears to be a hollow spring dowel. The only way to release the cover seems to be to drive the dowel further into the casing but I am concerned that I may damage the switch internals in doing so. Looks worth trying to drill it out? Brian 8227 8) Title: Re: Inition Switch Failure Post by: SanRemo78 on 08 February, 2014, 10:36:58 AM Before attempting to drill it out I'd be tempted to find a replacement lock/key in case you end up ruining it! If the pin is for locating the mechanism within the housing you might find there's a should to the pin and it's held in the locking position with a spring, a bit like the alloy brake callipers in the steel housing…
Have you tried Beta Boyz - the might have more knowledge than the rest of us? Guy Title: Re: Inition Switch Failure Post by: Peter W on 09 February, 2014, 10:59:13 PM I did manage to drill out the hard dowel & extract the switch assembly. I carried on dismantling as far as I could but the electrical contacts are in a plastic housing which is riveted together so I gave up, got on to Ebay, promptly found a new complete steering lock assembly. Should be delivered midweek & in the meantime I will drill out the shear bolts & remove the old lock.
Peter Title: Re: Inition Switch Failure Post by: Peter W on 13 February, 2014, 09:05:33 AM Sadly the switch that I found fits the Montecarlo only. It has a 4 pin connector, mine has a 5 pin so I am back to square one.
Peter Title: Re: Inition Switch Failure Post by: m tulloch on 16 February, 2014, 09:32:04 PM http://www.ebay.co.uk/itm/LANCIA-BETA-IGNITION-LOCK-ASSEMBLY-/231160412124
Title: Re: Inition Switch Failure Post by: Peter W on 03 March, 2014, 09:04:07 PM Geoff Holmes kindly sent me a Gamma switch cartridge in the hope that it might fit, sadly it didn't. When I looked at the used one on Ebay I found that a new one had also appeared there. I bid on the new one, got it, fitted it & the VX is back on the road.
Peter Title: Re: Inition Switch Failure Post by: neil-yaj396 on 04 March, 2014, 07:16:13 AM Glad you got it sorted in the end. Certain Beta parts can be tricky to get. My car was once off the road for 4 weeks waiting for a clutch cable. Then about 5 came up on eBay at once!
