Title: Dashboard re-covering Post by: bobhenry999 on 24 February, 2014, 10:24:54 PM Chaps,
Has anyone had a dashboard re-covered. My Flavia Coupe needs doing, and i`m not confident of doing it myself without making a complete mess of it. I was wondering if these guys who do whole car wraps on modern stuff might be able to help, what do you think. Bob Dow Title: Re: Dashboard re-covering Post by: fay66 on 25 February, 2014, 12:19:21 AM Bob,
I think any competent trimmers should be able to recover it for you, although cost might be another matter, I had one made for my 2c back in 2000 by a trimmers in Newport south Wales, I've also used Barton Brothers in Luton who took one of my seats apart and replaced all the rotten stitching, and did a nice job, so I don't really see it should be a big problem apart from the cost. Brian 8227 8) Title: Re: Dashboard re-covering Post by: brian on 25 February, 2014, 02:13:05 PM The problem often is the foam underneath goes brittle and trickles out as a nasty yellow dust and the edges curl in a most odd fashion. I have an OE aluminium dash top that came out of an 815 1500cc coupe and had no foam from new - the black vinyl was just glued on. I have not seen another car fitted with this type so assume it was a very early car! I always had the thought of making a mould and then fabricating in fibreglass and never have the problem again. I never got round to it and then sold my coupe.
You are welcome to borrow it if this is a route you wish to try. Brian Title: Re: Dashboard re-covering Post by: bobhenry999 on 26 February, 2014, 10:46:05 PM Brian,
My car is a 1963 one, and it does not have the vinyl over foam arrangement, which I have seen in many sedans, and fail as you mention. It sounds more like the one you describe. It currently is just a matt black hard textured painted surface, but it has some odd looking cracks in it. If it never had a vinyl covering, maybe I should go down the route of just having it resprayed with a textured coating sort of thing ? Bob Title: Re: Dashboard re-covering Post by: fay66 on 27 February, 2014, 09:25:27 AM Brian, Any photos Bob? it sounds like it might be that the paint surface has shrunk, but what you suggest might well be the way to go.My car is a 1963 one, and it does not have the vinyl over foam arrangement, which I have seen in many sedans, and fail as you mention. It sounds more like the one you describe. It currently is just a matt black hard textured painted surface, but it has some odd looking cracks in it. If it never had a vinyl covering, maybe I should go down the route of just having it resprayed with a textured coating sort of thing ? Bob Brian 8227 8) Title: Re: Dashboard re-covering Post by: brian on 27 February, 2014, 03:16:39 PM very odd! Mine was definitely covered with elderly vinyl but perhaps it was a fix for a problem early on in the car's life. It could of course be the sprayed covering was a fix for the original vinyl going!.............
I would be tempted to sand it down and spray it/enamel paint it or whatever and see how it looks with the fall back of covering your experiments with vinyl if total failure. Title: Re: Dashboard re-covering Post by: bobhenry999 on 27 February, 2014, 11:24:35 PM Guys,
Thanks for your thoughts/suggestions. I will post a couple of photos at the weekend to see if that helps with any suggestions. Thanks as always, Bob |
