Model Technical and Interest => Delta and Prisma => Topic started by: lancialulu on 14 August, 2014, 06:41:26 AM
Title: Delta windscreen drain "pipes"
Post by: lancialulu on 14 August, 2014, 06:41:26 AM
Does anyone know where these two small drain pipes (in the bottom corners of the windscreen recess) go?
One of mine is blocked with silt over the years and has been the cause of corrosion in one corner which I am dealing with.
I want to try to unblock this  very small pipe.
Title: Re: Delta windscreen drain "pipes"
Post by: simonandjuliet on 14 August, 2014, 07:03:49 AM
Can you put in a bigger pipe ?
Post by: sparehead3 on 14 August, 2014, 07:19:40 AM
No , and weirdly my 1300LX has taken to flooding if we get a heavy downpour and it's on a slope. Mine has a sunroof and this has filled with water and the drivers seat has gotten a soaking. So I've stuck a bit of plastic wire down the roof drain hole all the way till it stopped (which was somewhere in the front wing) so I was going to post on the forum whether I should expect to see it come out the bottom of the wing or whether this is the blockage ? (Like yours Tim I guess)
Post by: lancialulu on 14 August, 2014, 07:23:01 AM
I will investigate further.....
Post by: lancialulu on 14 August, 2014, 07:30:44 AM
pic shows a hose (11 and 12) of some sort and length...
Post by: the.cern on 14 August, 2014, 09:33:22 AM
Steve, i hope that Lancia learnt from the Beta of how not to do it!! In the Beta the sunroof channel drain pipe terminated within the sill at the bottom of the A post This meant a large volume of water was directed into the sill at a particularly vital point. I modified mine, obviously whilst the sill was opened up for surgery, by brazing a small copper pipe  through the bottom of the sill to which I attached the offending drain tube.
I hope the Delta does it better!!!  Good luck,
                                             Andy
Post by: lancialulu on 14 August, 2014, 09:58:46 AM
Here is the windscreen drain pipe. About 2 inches long.
Mine was bent over at the end so never ever worked.... >:(
It seem to drain between the inner and out wing. Cant get to excited to do anything other than make it drain as intended and waxyol the area as best as poss.  ;)
Post by: sparehead3 on 14 August, 2014, 11:24:59 AM
Well, there doesn't look to be any problem with rust and when it's happened we've dried it all out (dehumidifier sat in the car in the garage) and it's always parked in the garage with sunroof and windows open. I'll have a further look at the weekend but my 'wire' definitely went all the way down the windscreen and down the wing to at least the length of that pipe ...
Thinking about it, sticking something that'll get damp on the end of my bit of wire would say whether there was water still  present when there shouldn't be ....
Post by: lancialulu on 14 August, 2014, 12:31:51 PM
sticking a small hos pipe on the drain will show if it is working......
Post by: lancialulu on 14 August, 2014, 04:14:59 PM
I just examined the drain on the passenger. Side and it was loose on the metal so I fished it out and lo no pipe!
Must have blown off when I airlined it. No chance of finding it as access via the engine bay is not possible unlike on the other side where a small gap allows a small hand / torch in to see what is going on.
Luckily I had some old pipe as it is the same as the Fulvia fuel return cavis benz... I now need to work out where it will drain too....
Post by: fay66 on 14 August, 2014, 11:55:44 PM
Are there drain tubes at the back of the sunroof? if not perhaps learning from the Delta, Dedra has 4 drain tubes!
8227 8)
Post by: lancialulu on 20 August, 2014, 06:19:15 AM
seems the Integrale has 4 drains.
see for more info.
http://www.berlinasportivo.com/Technical/lancia/hfintevo1/bodywork.pdf
Looks like headlining will need to come out....
Post by: chriswgawne on 20 August, 2014, 08:44:14 AM
What a great website for Delta, Dedra and Thema owners who want technical info in English. Never seen it before.
Post by: lancialulu on 20 August, 2014, 09:28:55 AM
Yes!!
Does anyone know what the pressure spec is for the fuel breather on later Lancias (Delta etc). My one way valve has gone 2 way!!
Part number is82424480.
Post by: sparehead3 on 20 August, 2014, 11:21:03 AM
Agreed, I've added a "technical information" sticky topic onto this board and put the link in there
Post by: fay66 on 20 August, 2014, 05:04:34 PM
Hi Chris,
I see they have the Thema 8.32 Manual in German on the site.
for anyone who needs the information I'm still the Dedra Technical Advisor, I have nearly all the Dedra manuals and technical supplements in English including the automatic manual, I have the Dedra integrale 4x4 Manual in Italian, the HF Turbo and the integrale share engines and many other parts so it's also helpful for HF,l've never been able to get my hands on a Dedra HF manual but many parts are the same or similar to the higher spec Dedras.
I also have Thema Manuals including the rare series 3 manuals.
Y10 I have 1st series, 2nd series that never came to the uk, manuals for the Y10 4x4 and the selectronic supplement.
8227 8)
