Title: ECU Gone bonkers !! Post by: HF_Dave on 16 December, 2014, 09:51:57 PM I have an 03 Ypsilon which is a great little car I laid it up and the battery went flat so I fitted a new one , the only problem is the power surge when I fitted the new Battery caused the ecu to think there was a fault with the engine. the car runs fine but the engine light is on and the dash reads complete engine failure !! ???. I brought it to a couple of experts and they said that the ecu was damaged when the new battery was fitted and it would need to replace it . The cost of an ecu is nearly the value of the car , and this is for a re-built one ! Does anybody know anyone who could help with this problem . I am afraid it would fail the NCT Test which is the same as the MOT test only a lot stricter ! Thanks David. :)
Title: Re: ECU Gone bonkers !! Post by: Parisien on 16 December, 2014, 10:13:30 PM Of any use?
http://www.subito.it/accessori-auto/centralina-motore-lancia-ypsilon-1-3-mtj-anno-2008-messina-68749431.htm http://www.subito.it/accessori-auto/lancia-ypsilon-centralina-d-iniezione-nuova-1-2-milano-109249620.htm http://www.subito.it/accessori-auto/centralina-lancia-ypsilon-livorno-109058146.htm http://www.subito.it/accessori-auto/centralina-alzavetro-sinistro-lancia-ypsilon-1-2-napoli-102374706.htm P Title: Re: ECU Gone bonkers !! Post by: lancialulu on 17 December, 2014, 11:17:26 AM Have you disconnected the battery and then carefully reconnected I think earth last.??
Title: Re: ECU Gone bonkers !! Post by: HF_Dave on 17 December, 2014, 07:39:51 PM I have tried disconnecting the battery and then joining the tow battery leads together with the battery out, This I believe this drains away any power in the ecu and turns it off completely. This made no difference . Would the battery be the problem ? when I crank the engine over the dash lights nearly go out completely , the battery is new but a bit small for the tray and a bit shorter in height ! Maybe the ecu needs more power ? Thanks David.
