Buy, Sell and Search => Spares required => Topic started by: rogerelias on 05 September, 2007, 08:12:56 PM
Title: Flavia Gearbox.
Post by: rogerelias on 05 September, 2007, 08:12:56 PM
Has any one got a Flavia coupe 1800 gearbox that they are fed up tripping over, that they wish to sell for sensible money?
Title: Re: Flavia Gearbox.
Post by: sweeet-twincam on 20 February, 2008, 06:48:25 PM
Hello ,i believe i have a Flavia gear box under my bench, can you give me part numbers to match up to it ?
 Thank you
Post by: rogerelias on 20 February, 2008, 08:44:44 PM
Hello Mark. Thanks for the reply, i have found and fitted one now, but thanks for the reply. Regards Roger.
Post by: Richard Fridd on 23 September, 2010, 05:23:45 PM
how does this 'box compare with a fulvia saloon s2 box? 'fitting +ratios' as i have been advised by more than one member that fulvia  saloons are under geared for some drivers tastes.best regards richard
Post by: fay66 on 23 September, 2010, 10:36:24 PM
Richard,
If you Fulvia Berlina goes as well as the one Don Cross owns when you have it back on the road I don't think you'll be disappointed, I suspect if you are being advised that Saloons are undergeared then IMO they are talking about Series 1 saloons such as my 2c, which is definitely undergeared with 70mph being nearly 4500 RPm, on the other hand as over a Ton (Imperial) of car is being pulled around by 1091cc anything higher unless somewhere where it's flat, such as Holland, where a friends 2c has been geared up to good effect, higher gearing might be a mistake, I certainly wouldn't have liked to try climbing the Alps on my way back from Turin in 2006, if I had gone with the higher gearing theory, really a case of "horses for course".
In the "concise Repair Shop Manual" it shows that the 1.3 saloon is at least 90kgs heavier than a 1.3 coupe and the 1.3 coupe produces 90bhp @6000rpm whereas the saloon only produces 85bhp @ 6000 rpm.
So with the saloon being 5 BHP down, as well as weighing considerably more than the 1300 Coupe I don't believe making the gearing higher is going to help the performance to a great degree, if at all; far better to see how satisfied you are with the performance once you have it back on the road and then see if you really think it's a worthwhile modification, personally I don't think you will.
With the top speed of the series 2 saloon shown as being 99.4 mph as opposed to a 105mph for the coupe, is it really a worthwhile mod?
I'd rather go for a set of Dellorto's, which are a great improvement over the standard solexes.
8227
 8)
