Title: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 28 January, 2015, 10:59:42 AM In Glasgow.
Let me know if interested and I will forward email. I am advised a best price secures. Tim Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: peteracs on 28 January, 2015, 03:29:35 PM Curious what it is off, it is early type with exhaust ports at the back, but not off any Beta AFAIK (unless early Saloon)?
Peter Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: simonandjuliet on 28 January, 2015, 03:53:02 PM "AFAIK" - "as far as I know" ????? Not come across that before
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 28 January, 2015, 03:54:42 PM The part number on the exhaust manifold cross references with Beta 1.3.....AFAGK (as far as Google Knows!)
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: SanRemo78 on 28 January, 2015, 06:43:49 PM Was the Beta 1.3 available with a cam mounted distributor? Thought they were all block mounted at the front with only the i.e. and VX having the dizzy there?
Guy Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 28 January, 2015, 06:52:29 PM Thats why I think it could be a Delta 1.3 but the exhaust number is confusing.
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: Sebastien on 28 January, 2015, 07:06:19 PM Delta 1.3 and Delta 1.5 were SOHC, not DOHC.
DOHC came with the Delta 1.6 GT. Best use for that lump of (corroded) aluminium would be as a doorstopper (IMHO);D Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: SanRemo78 on 28 January, 2015, 09:30:13 PM It's not Beta, not with those engine mounts. None the wiser though! Carb ducting ought to give someone a clue?
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 28 January, 2015, 10:37:18 PM Very Delta like then? An early 1.6??
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: peteracs on 28 January, 2015, 11:23:16 PM "AFAIK" - "as far as I know" ????? Not come across that before Hi Simon Oops, sorry about that.... Must use full words Peter Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: peteracs on 28 January, 2015, 11:28:33 PM What made me think it was maybe early Beta was what looks like a metal cover for the timing belt, the later Betas all had yellow plastic ones I think, but the engine mounts are definitely not Beta as mentioned, hence wondering if it was an early saloon, but I thought all of them had a similar mounting scheme.
So maybe the engine was transplanted into something else? The answer is to get the number near the oil filter which would settle it. Peter Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: fay66 on 29 January, 2015, 09:26:22 PM What made me think it was maybe early Beta was what looks like a metal cover for the timing belt, the later Betas all had yellow plastic ones I think, but the engine mounts are definitely not Beta as mentioned, hence wondering if it was an early saloon, but I thought all of them had a similar mounting scheme. Can't say I've ever seen that cambelt cover on a Delta?So maybe the engine was transplanted into something else? The answer is to get the number near the oil filter which would settle it. Peter Brian 8227 8) Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 29 January, 2015, 09:51:08 PM Its seems not to be "Work In Progress" the way all the pipes have been cut. The cam covers do not have Delta recessed fastners. Could it be a Monte???
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: peteracs on 29 January, 2015, 10:23:55 PM Not convinced the mount or the air filter is Monte. I guess we need the engine number...
Peter Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 30 January, 2015, 07:05:09 AM The seller is not able to get more info. Based in Glasgow so if anyone wants to go look......
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: SanRemo78 on 30 January, 2015, 08:56:56 AM Not convinced the mount or the air filter is Monte. I guess we need the engine number... Peter Not a Monte motor Peter, the dizzy is in the wrong place for that, Monte Carlos are on the exhaust cam bank... It's a mystery alright! Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: neil-yaj396 on 30 January, 2015, 05:53:50 PM The oil filler is at the wrong end for a Beta. The dizzy and engine mounts are also non-Beta as mentioned. Prisma or Dedra?
Title: Re: 1.3 Beta or maybe Delta Engine / Airbox / Gearbox Post by: lancialulu on 30 January, 2015, 11:13:18 PM Early 1.6 Delta. (Or Prisma)
