Title: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: Parisien on 29 October, 2015, 12:24:58 PM This is an article taken form the ALR newsletter by Peter Renou their membership secretary, am sure they won't mind me posting it up on our forum (Morris Parry is fine with it!)
Please see photos too, one top side, one side on (hoping these come out as they didn't appear as photos on my hard drive....oh dear didn't work) The photos are on the ALR newsletter site page 19 of July 2014 edition) Aurelia Cylinder Head Removal Removal of a stuck cylinder head is a perennial Aurelia problem – Appias too for that matter. All sorts of pullers have been tried including hooks in the inlet and outlet ports with mixed success. However, I recently visited Morris Parry and he showed me the ingenious and simple method he used to remove a thoroughly stuck B12 head. Morris’ puller is a 3/8” steel plate drilled so it can be bolted to the rocker block mounts. It is tapped 8x1mm over the available head studs on the pushrod side of the head. The ten bolts were progressively tightened in sequence and the head came off easily. The 1mm pitch of the bolts allows good feel of the pressure being applied to the head studs. I can provide a sketch which shows the centres of the drillings. by email if desired. P PS Maybe some knows better how to save, then up load the photos? Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: the.cern on 29 October, 2015, 01:25:28 PM As you say Frank, Morris and James used this technique on a B12. I did the same for my B20 (see 'A B20 Story') and also recommended it to 'Clarkey' for the Appia with which he is fighting at the moment!!! (The story so far)
It really is as effective as described, it just takes some time to actually mark out, drill and tap the plate. I found that some of the holes I drilled did not EXACTLY match the head studs, but enough did to make it an easy and effective puller. Andy Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: lancianut666 on 29 October, 2015, 04:20:10 PM Hi all Clarkey here
anyone got a picture of this puller on a head still trying to visualise it... as the Appia head is inverted V is the plate flat or bent into an upside down V? Puzzled of Hartlepool Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: Parisien on 29 October, 2015, 04:28:02 PM Hi Clarkey, there are two photos on this web site, go to members area, log in using vincenzo2go, choose newsletters 2011-15, then select July 2014 to download, go to page 19 for the photos
http://alr.org.au/members-area/newsletters-2011-2015/ P Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: Richard Fridd on 29 October, 2015, 05:58:34 PM Password protected?
Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: Parisien on 29 October, 2015, 06:04:47 PM Vincenzo2go
Assuming correct spelling of his name P Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: the.cern on 29 October, 2015, 06:12:13 PM This is my puller on a B20 head. There are nuts on the 6 rocker block studs, they secure the head to the plate. The bolts in threaded holes through the plate bear onto the ends of the head studs. Simply by tightening these bolts the head may be lifted in a controlled true manner.
I am struggling to select the photographs, so I hope all is well. Andy Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: Parisien on 29 October, 2015, 06:13:54 PM Excellent Andy, so how is your engine coming along now?
P Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: lancianut666 on 30 October, 2015, 07:15:27 AM Ahh... so it has 2 separate heads.. Be a bit tricky bending 3/8 plate to sit across the Appia head and then you would need to drill the holes at an angle perhaps 2 pullers plates one each side then bolted together somehow.. Don suggested locking nuts on the studs and taking them out then small wedges around the edges..
Thanks ever so much for sharing this Clarkey Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: frankxhv773t on 30 October, 2015, 11:25:24 AM That's an interesting conundrum. I guess you can't use the rocker mountings as the pickup point for the plate because they are not in the same plane as the head studs. Is there any alternative fixing to which you can attach the plate?
Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: lancianut666 on 30 October, 2015, 12:10:52 PM Hi
I will have a look next time I am at the unit but possibly the inlet and exhaust manifold mounting studs as they are at 90 degrees to the head studs. I have a spare cylinder head that came with the car to experiment on and I looked at the possibility of using the rocker shafts with some threaded bar and a U shaped bracket... Clarkey Title: Re: So, just how do you remove an Aurelia cylinder head.....read on!? Post by: the.cern on 30 October, 2015, 12:31:22 PM The only issue is how to attach the plate to the head. Based solely on the photograph of the dissembled engine, I think that straps bolted onto the inlet and exhaust manifold studs and welded (could be bolted if you do not have access to a welder) to the plate would be sufficient.
Then it's all standard stuff!!!! Good luck. Andy |
