Title: engine mounts Post by: bali on 09 October, 2007, 09:26:01 PM i was wondering if the prisma has the same engine mounts as the 1.6 delta 89.
everytime you rev the engine it flex's alot and ive had to replace the exhaust flexi pipe a numebr of times. i was wondering if mine might be missing a mounting from the front of the engine Title: Re: engine mounts Post by: A1.6HPE on 17 October, 2007, 07:05:00 PM Yes, exactly the same, assuming same engine type.
The steady "pad" under the floor is the usual suspect. I had one where the long through bolt was seized into the bush. Had to release it from the transaxle casing and unscrew the asembly with the bolt -LOL. |
