Title: Lancia Belna engine removal/overhaul Post by: Dikappa on 15 May, 2016, 08:04:16 AM As Belna's are quite new to me, and we are now attacking a friends Belna that did not reach the last european Sliding Pillar due to engine failure, could use some advise:
What is the best way to remove the engine? Does it come out together with the gearbox or can it come out separate? Is there any data on the engine measurements available, I've the 'revue technique' on the Lancia Belna, which gives some information, but not much. I already found the engine has been converted to modern shell bearings in the past. Thanks for any advise, Koen Title: Re: Lancia Belna engine removal/overhaul Post by: JohnMillham on 15 May, 2016, 09:11:09 AM It's much easier to remove the engine and gearbox together, after removing the head. It all comes out forwards and tilted when the radiator is removed. In what way did it fail?
Regards, John Title: Re: Lancia Belna engine removal/overhaul Post by: Dikappa on 15 May, 2016, 04:38:43 PM I it has a big end bearing failure on the second cylinder (when counting from the nose of the crankshaft)
Title: Re: Lancia Belna engine removal/overhaul Post by: JohnMillham on 15 May, 2016, 06:54:55 PM I it has a big end bearing failure on the second cylinder (when counting from the nose of the crankshaft) That's No. 1 cylinder as Lancia named them, being the front one on the near side. How did you determine that a bearing has failed? Regards, John Title: Re: Lancia Belna engine removal/overhaul Post by: Dikappa on 16 May, 2016, 06:20:06 AM I already removed the side covers with the engin in situ and could feel by hand that the big end had play, I then removed the cap.
Hopefully will get the engine out today, will post some pictures then. @john: thanks for the concern and the advise! Title: Re: Lancia Belna engine removal/overhaul Post by: brian on 16 May, 2016, 12:17:22 PM Agree with John although with a flat radiator Augusta the head can stay on. There were bits of information about the engine in an LMC Journal - I think 1974 - which together with a handbook was all I had in the 70s to get mine together. There is much more help around now on the forum so just ask!
Brian Title: Re: Lancia Belna engine removal/overhaul Post by: Dikappa on 16 May, 2016, 02:52:01 PM Engine is out.
In the end I decided, having the luxury of the car being on a 2 post lift, to first remove the gearbox seperately from underneath, which made it then a very simple job lifting the engine straight out. As I was working alone I thought this was the most secure way of doing the job without damaging the body work accidently when lifting and tilting the complete engine gearbox assy out. It took me 3.5 hours. I'll now have a chat with the engine shop man to know how he would like to ahndle the job, and how much I can still do myself. Title: Re: Lancia Belna engine removal/overhaul Post by: the.cern on 16 May, 2016, 09:47:29 PM I seem to recollect that the first time the engine came out of mine I left the gearbox in the car. I then lifted the engine out, by hand, with my brother, accompanied by much cursing! On the second occasion, being a lone worker, I placed a trolley under the sump, disconnected all the control cables, wires, gearlever etc etc and lifted the car off the engine. I then wheeled the engine out from under the car and lowered the car back onto its wheels .... quite simple really.
Andy PS should you be interested, the same MO may be used to remove an electric motor from a Southend pier train carriage. I did this, again lone working, in the middle of a field in N Wales. More difficult than with the Gussie .... a driven carriage for a Southend pier train weighs 6 tons! Title: Re: Lancia Belna engine removal/overhaul Post by: fay66 on 16 May, 2016, 11:21:33 PM I seem to recollect that the first time the engine came out of mine I left the gearbox in the car. I then lifted the engine out, by hand, with my brother, accompanied by much cursing! On the second occasion, being a lone worker, I placed a trolley under the sump, disconnected all the control cables, wires, gearlever etc etc and lifted the car off the engine. I then wheeled the engine out from under the car and lowered the car back onto its wheels .... quite simple really. The Varied skills and interests of Lancisti never cease to amaze me, tell us more Andy ;DAndy PS should you be interested, the same MO may be used to remove an electric motor from a Southend pier train carriage. I did this, again lone working, in the middle of a field in N Wales. More difficult than with the Gussie .... a driven carriage for a Southend pier train weighs 6 tons! Brian 8227 8) Title: Re: Lancia Belna engine removal/overhaul Post by: davidwheeler on 23 May, 2016, 08:43:00 AM Routine way to take engine/gearbox/subframe from a Fulvia of course.
Title: Re: Lancia Belna engine removal/overhaul Post by: peteracs on 23 May, 2016, 10:23:46 AM PS should you be interested, the same MO may be used to remove an electric motor from a Southend pier train carriage. I did this, again lone working, in the middle of a field in N Wales. More difficult than with the Gussie .... a driven carriage for a Southend pier train weighs 6 tons! Hi Andy Most intrigued, Southend Pier carriage ends up in North Wales, you do need to explain more I think...... Peter Title: Re: Lancia Belna engine removal/overhaul Post by: fay66 on 23 May, 2016, 10:26:28 AM Routine way to take engine/gearbox/subframe from a Fulvia of course. David I was referring to the Southend Pier Carriage Motor Removal.Brian 8227 8) Title: Re: Lancia Belna engine removal/overhaul Post by: the.cern on 23 May, 2016, 08:10:40 PM I think it is probably best that I post a response re the pier train in the 'Other Non-Lancia Models' section.
Andy |
