Model Technical and Interest => Fulvia => Topic started by: Andrew2015 on 21 May, 2016, 09:52:38 PM
Title: Advice please
Post by: Andrew2015 on 21 May, 2016, 09:52:38 PM
Hello, I wonder if anyone is able to offer me some friendly advice please regarding the following? I have been hunting for a Fulvia and have recently viewed a an early 1.3 S1 car with a higher mileage (circa 90K), although I guess given the cars age (nearly 50 years) then probably not that unusual. The particular car had an engine rebuild circa 25 years ago at around 60K and from all the paperwork appears to have been well looked after since then. Bodywork / subframes / brakes / gearbox etc all look to be sound so it is really only the engine that I have a question mark over.
On driving the car I didn't pick up on any odd noises knocks or rumbles although it was a bit smoky on first starting up. Oil pressure however was good (mid-gauge). Being new to Lancia's, I have no idea on how much longer an engine of this age would ordinarily soldier on for before next needing serious attention? Should I even be concerned about the higher mileage (given the car looks to have been cherished and used, not left standing)?
I know it is a bit of a 'how long is a piece of string' question and the answer may well be 'it depends on how well it has been treated / maintained', but any advice that can be offered would be very much appreciated. Many thanks. Andrew
P.S. - apologies in advance if this has been posted in the wrong area of the forum site.
Title: Re: Advice please
Post by: neil-yaj396 on 22 May, 2016, 06:58:12 AM
All Lancia engines are very robust. As you say 90K isn't a lot over 50 years! I'm surprised that the engine needed major attention at 60K, but perhaps it had a hard life in its early days. Oils have also improved in the last 25 years.
If the car is spot on body, brakes and subframe wise, I wouldn't be put off by that mileage.
Post by: davidwheeler on 23 May, 2016, 08:40:54 AM
If oil pressure is mid gauge at 3000 rpm when hot then all is well at the bottom end.   A bit smoky at the start could well just be down to the rich mixture from the starting carburettors.  It should rev. freely to 6,000+ rpm (on the right fuel!) without rattling.  30k after an engine rebuild is nothing really, it sounds like a good buy!   If the worst came to the worst it is not a difficult engine to rebuild but I would not anticipate it needing that for a good many years.   Use at least 96 octane fuel with lead substitute additive as the 1300 engine has non hardened valve seats.
Post by: Andrew2015 on 23 May, 2016, 07:03:09 PM
Hello David / Neil, Many thanks for your responses, advice and help which are very much appreciated. I will be giving the car serious consideration with this in mind. Kindest regards, Andrew
Post by: stanley sweet on 24 May, 2016, 11:40:31 AM
I've been driving my 1.3 for 22 years (including 4 years sprinting and hillclimbing) without a rebuild. I change the oil and filter every 3500 miles. I don't drive it hard until all the temperatures are up. I also push the choke in almost immediately. It's still showing normal oil pressure. Be aware that when hot the oil pressure needle does hover near zero. That would scare a lot of people if they wasn't aware of it. Treated properly they are pretty bulletproof.
Post by: rogerelias on 24 May, 2016, 07:20:57 PM
My 1600HF has just clicked over to 98,000 on the way back from the GNW ::) and I drive it fairly hard , seems to ok, not been rebuilt to my knowledge, so I wouldn't worry too much, as others have said. Just enjoy it, they are fun to drive  ;D
Post by: stanley sweet on 25 May, 2016, 08:27:00 AM
Just realised - when I said the oil pressure needle hovers around zero when hot I should have made clear that this is at idling speed only - not at driving speeds.
Post by: Andrew2015 on 25 May, 2016, 08:36:24 PM
Hello Roger / Stanley, Many thanks for taking the time to post some advice - Looks like I need not be overly concerned and as you say just enjoy the car (which I now intend to go ahead with assuming a deal can be struck) - Will let you know if I end up the proud owner and thanks to all again for the help. Best wishes Andrew
