Model Technical and Interest => Flaminia => Topic started by: NGK on 15 September, 2016, 11:20:03 PM
Title: Toe in on a flaminia?
Post by: NGK on 15 September, 2016, 11:20:03 PM
Hi, Could anybody tell me what the toe in is in degrees on a flaminia PF coupe 2.5 3B?
Title: Re: Toe in on a flaminia?
Post by: Jay on 16 September, 2016, 07:09:01 AM
According to the repair manual
1 to 3mm measured on the rims with car fully loaded
1.5 to 4mm measured on tyre side walls with car fully loaded
Post by: NGK on 16 September, 2016, 04:17:28 PM
Hi Jay,
Thanks for that, have you any idea what that is in degrees and minutes, I have an old wheel alignment thingy that that just uses those.
Post by: Jay on 17 September, 2016, 07:35:18 PM
Sorry the manual i have only has it mm and not in degrees, i guess if you measure the diameter of wheel at the rim you could work the angle
Post by: Dilambdaman on 23 September, 2016, 09:53:09 AM
This may help.
www.trackace.co.uk/manual/conversion%20chart.pdf
Robin.
