Title: Flywheel starter ring Post by: davidwheeler on 03 October, 2016, 10:19:19 AM Old Boot needs a new one. In days of yore I took the flywheel to a local motor factor and got it back a week later with a new ring fitted but that does not seem to obtain any more. anyone any ideas please?
Title: Re: Flywheel starter ring Post by: Jaydub on 03 October, 2016, 05:27:32 PM Drill a hole or 2 in the flat face of the ring gear, noting which way the lead on the teeth faces and finally split with a chisel down between the teeth. Then if you don`t have access to a welding torch, take it to your local bodyshop with a welding set and they should heat it up and drop it on for you, again making sure the lead on the teeth are facing the correct way.
Hope that helps, that`s the way we`ve always done it. John Title: Re: Flywheel starter ring Post by: davidwheeler on 04 October, 2016, 08:46:01 PM Yes, I know that bit. The problem is finding a new ring!!!
Title: Re: Flywheel starter ring Post by: Tony Stephens on 05 October, 2016, 07:54:40 AM IIRC Jonathan Reeve is obtaining a quotation for me on behalf of the Consortium. I will remind him.
I think Belcher Engineering, much beloved by a group of Lambda owners, are specialists in this area. Title: Re: Flywheel starter ring Post by: Jaydub on 05 October, 2016, 07:51:06 PM Dohh!!
Sorry David, I had n`t read your email correctly. John. Title: Re: Flywheel starter ring Post by: davidwheeler on 05 October, 2016, 08:28:04 PM IIRC Jonathan Reeve is obtaining a quotation for me on behalf of the Consortium. I will remind him. Yes, please pursue this as I suspect quite a lot of people will need one at some time or another! F W Thornton have nothing suitable.I think Belcher Engineering, much beloved by a group of Lambda owners, are specialists in this area. Title: Re: Flywheel starter ring Post by: JohnMillham on 05 October, 2016, 09:42:07 PM I think the Australians can supply them, but that might not be economical. If Kim was on the Internet, we could ask him!
Regards, John Title: Re: Flywheel starter ring Post by: Parisien on 06 October, 2016, 10:30:40 AM If these arent too big/heavy, have a friend coming home at Xmas, let me know as postage horrific!!!
P Title: Re: Flywheel starter ring Post by: davidwheeler on 07 October, 2016, 11:48:32 AM That's a long time to wait! Better than nothing though. I think it is time the Consortium listed them, I cannot be the only one with a damaged ring.
Title: Re: Flywheel starter ring Post by: Jaydub on 07 October, 2016, 07:09:47 PM Hi David
These people might be worth a call. F W Thorton, Telford, Shropshire. Tel. 01952 252892. They specialise in vintage engine parts including Ring Gears. John Title: Re: Flywheel starter ring Post by: Tony Stephens on 07 October, 2016, 07:46:52 PM That's a long time to wait! Better than nothing though. I think it is time the Consortium listed them, I cannot be the only one with a damaged ring. Never had a single request! I imagined that people had piles of old flywheels lying about. However I will look into it. Tony S Title: Re: Flywheel starter ring Post by: davidwheeler on 10 October, 2016, 08:30:28 AM Hi David Been there, done that, no joy.These people might be worth a call. F W Thorton, Telford, Shropshire. Tel. 01952 252892. They specialise in vintage engine parts including Ring Gears. John Flywheels are not interchangeable as engine balance depends on what you have in the way of big ends. Conversion to shells severely affects balance as will different pistons etc. |
