Title: Shock absorbers Post by: simonandjuliet on 24 August, 2017, 06:45:56 AM Does anyone have specifications for Fulvia rear shocks please ? Length open/closed and bolt diameter
I hadn't realised that Magnetti Marelli made shock-absorbers ! (ref GB47341) Thanks Title: Re: Shock absorbers Post by: Sliding Pillar on 24 August, 2017, 07:52:50 AM This is the data for the rear shocks, I have also included the front ones for completeness.
I'm not sure it gives you exactly what you want though, as all the measurements are for compression/extension rather than lengths. Title: Re: Shock absorbers Post by: lancialulu on 24 August, 2017, 12:40:48 PM Believe the extended length should be c 422mm (eye to eye), Equivalent Spax is G3318 but cannot find any data now on line.....
