Supposed to cool the brake discs I guess. A 2CV has a similar set up (also unnecessary).
David it is an exhaust manifold hot air pick up to carbs and goes via a large hose (which gets in the way of the flywheel timing window) to the air filter box as a measure to prevent carb icing in deepest winter….
