Author Topic: Fulvia Dashboard Lighting  (Read 115 times)
MartynT
  • Member
« on: 06 April, 2025, 01:30:34 PM »
Hi all,
The lighting that illuminates my dash dials is absolutely terrible so I was thinking about changing the standard festoon lamps for LED versions. Has anyone done this and if so, is it an improvement?
Cheers, Martyn.
  • Permanent resident
Re: Fulvia Dashboard Lighting
« Reply #1 on: 06 April, 2025, 01:37:31 PM »
 I have not used LED bulbs but a good condition reostat can restore brightness
  • Events Co-ordinator
« Reply #2 on: 06 April, 2025, 02:27:09 PM »
I would recommend LEDs a vast improvement and perhaps by pass the rheostat too
386
1973 Fulvia S2 1.3
  • Press Officer
« Reply #3 on: 06 April, 2025, 03:59:22 PM »
Personally I only use LEDS for the green indicator lights. I don't like instruments "in my face" at night. As you get older your eyes need all the help they can get and modern badly designed head lights don't help but as Richard said if the electrics are not degraded the panel lighting is fine.
HBG
  • Megaposter
« Reply #4 on: 06 April, 2025, 07:53:15 PM »
I've had good results with leds behind the dials. I didn't change the lamps behind the indicators, handbrake warning etc as they seem bright enough. The rheostat still sort of works but I leave them on full brightness which is about right. Before the change I could barely make out the dials. I got the lamps from classiccarleds. I'll see if I can find a photo.
HBG
  • Megaposter
« Reply #5 on: 06 April, 2025, 08:03:29 PM »
Think it was these in warm white. Would suggest you check before ordering.
