Author Topic: Parts required for Delta HPE / Dedra  (Read 10899 times)
M666 EVO
  • Lapsed
  • Member
« on: 19 February, 2018, 09:23:41 AM »
Hi, the car has been to the garage regarding some recent damage and I need the below parts - I believe they share with the Dedra?
Rear sub frame - part 92339919
Right rear suspension arm - 7603699
Any help will be greatly appreciated. You never know, someone might have them lying about  ::) (no chance I know!)
Russ
  • Permanent resident
Re: Parts required for Delta HPE / Dedra
« Reply #1 on: 19 February, 2018, 11:45:31 AM »
Thema Dedra Consortium is the obvious place to get these. Also check compatibility on eper because they are probably common to Alfas. That's where I got a replacement for my Dedra.
« Reply #2 on: 19 February, 2018, 11:58:12 AM »
You should look at Tipo, Tempra, Fiat Coupe, Dedra, Alfa 145 - 146 - 155 for the axle beam. The part number you have given for the trailing arm is actually the whole sub assembly not just the arm. Yoou need to be careful with the arm because they changed the camber at some point. You don't want to end up with a replacement with a different camber to the other side.
M666 EVO
  • Lapsed
  • Member
« Reply #3 on: 19 February, 2018, 02:47:39 PM »
Yeah so as I understand it, 92339919 is the whole frame and 7603699 is the RH arm - I have found the new LH & RH arms on Italian ebay so I would need to replace both for the new camber setting.
So theoretically I only need the frame as I can buy the 2 new arms, but if I can find the original RH then that will pair OK with the LH that is undamaged on the car.
GialloHPEIan
  • Senior Member
« Reply #4 on: 19 February, 2018, 04:35:20 PM »
ePER pic attached. Info says camber was changed from 15/12/95 so unless you have an early car you should be ok.
11
7603697
SWINGING ARM LH
C2064
01
11
46460171
SWINGING ARM LH
D2064
01
11
7603699
SWINGING ARM RH
C2064
01
11
46460172
SWINGING ARM RH
D2064
01
I've tried to copy and paste part no.s but doesn't look right pre-posting so might not make sense.
1998 Delta HPE 2.0HF Turbo 16v
1968 Land Rover Series IIa Lightweight
2018 Fiat Ducato L2H2
2011 BMW 1 Series 118i M-Sport Convertible
Prev.Lancias: Beta Spyder 2000('80) Delta HF Turbo Martini('88) Prisma 1600('86) Montecarlo('77) Dedra Turbo(
GialloHPEIan
  • Senior Member
« Reply #5 on: 19 February, 2018, 05:01:43 PM »
This pic should show all part no.s for the rear suspension setup. Hope it helps.
Regards
Ian (6610)
« Reply #6 on: 19 February, 2018, 06:56:37 PM »
With this setup being used on so many FIAT group cars I would think you stand an excellent chance of finding good second hand items in the UK. I didn't have any trouble finding two Alfa used part specialists within ten miles of home (which does rather depend on whether or not you live in the Outer Hebrides).
M666 EVO
  • Lapsed
  • Member
« Reply #7 on: 20 February, 2018, 01:23:36 PM »
I can't seem to get into EPER, I keep getting an error message. Any ideas or do I need to sign up to something?
All help so far is really appreciated
And I live in London so should really have a number of Alfa places near by. The only problem is its with the garage going through the insurance route so depends how much effort they're prepared to go to.
Russ
GialloHPEIan
  • Senior Member
« Reply #8 on: 20 February, 2018, 07:13:16 PM »
Hi Russ
I've now put two and two together and realised that the "Delta value" post and this one are connected. So I see you do have a 1995 car, so you will definitely have to replace both sides due to the camber change in December of that year (or a complete s/hand one of course).
Re. ePER, I just bought a disc on eBay and installed it on my computer. I have only just updated to the latest version available to the public that runs on Windows 10 here:-
https://www.ebay.co.uk/itm/273069840016?ViewItem=&item=273069840016
I'm not aware of a version that would work on Apple products but there used to be a Fiat forum that you could access ePER from, but think it was removed. I am happy to find part numbers for you on my system if you are stuck, I just need your chassis number. It also tells you what other vehicles a part is used on (if any) which is very useful.
Regards
Ian (6610)
« Reply #9 on: 20 February, 2018, 07:34:14 PM »
I have been blocked on the Fiat forum too but was able to get in through the Polish Fiat club
 http://eper.fiatklubpolska.pl/navi?SGRP_COD=5&MOD_COD=160&COMM_MODEL=TIP&SBMK=F&COUNTRY=001&DRIVE=S&MAKE=F&CAT_COD=MP&GRP_COD=443&LANGUAGE=6&ALL_FIG=0&RMODE=DEFAULT&KEY=PARTDRAWDATA&EPER_CAT=SP&GUI_LANG=6&ALL_LIST_PART=1&PRINT_MODE=0&PREVIOUS_KEY=SUBGROUP&SB_CODE=-1&WINDOW_ID=1&
I then pasted the part name into google translate.
As I said earlier I found the sub frame from an Alfa breaker and I got trailing arms off e-bay but that was a few years ago.
M666 EVO
  • Lapsed
  • Member
« Reply #10 on: 01 March, 2018, 03:54:29 PM »
Update: After a PM to Simon Davis, then a mail to Paul Baker who I haven't spoken to for about 12 years, he told me about Neil at Project Lancia. So it seems I might have found the guy to do the work on my car. Fingers crossed!
Thanks to all involved.
I do still need to find the parts though as many places haven't got them!
Angle Grinder
  • Megaposter
    • http://www.secret-scotland.com
« Reply #11 on: 07 March, 2018, 10:42:13 AM »
The Thema Dedra Consortium will most likely have the rear subframe, but anything that we have in stock will be pre-1995 from a UK sold Dedra that has been scrapped for spares.
Unfortunately, our parts man is just recovering from some serious surgery so I don't wish to pester him at this point in time.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
M666 EVO
  • Lapsed
  • Member
« Reply #12 on: 10 September, 2018, 12:29:51 PM »
Just revisiting this thread - is the parts man up and about?
I still need the sub frame if there is one lurking about
