22 December, 2024, 02:34:46 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
forum.admin@lanciamc.co.uk
events@lanciamc.co.uk
- To Join the club go to
Home
Help
Search
Calendar
Register
Model Technical and Interest
Aurelia
Oil loss
Pages: [
1
Go Down
« previous
next »
Author
Topic: Oil loss (Read 4455 times)
Niels Jonassen
Oil loss
on:
26 April, 2018, 09:23:36 AM »
I was wondering why oil was dripping from the underside of the Aurelia. A lot of it. Checking the oil level I discovered that almost all the oil had gone. It appeared that the oil was virtually pressed out of the engine. But where? With the front of the car on stands I started the engine and crawled underneath. After having looked at various possible places I saw a drop of oil per second from the front right hand engine mounting. One wonders what oil does at an engine mounting, but that is where the oil pressure for the front chain comes. To get the mounting off I had to remove the radiator. Otherwise there was no room for the spanner. I was surprised to find that there was no gasket. In the parts book there is a gasket shown, and in my box of gaskets I found one. I have had the car since 1977, and I have never had the mounting off. Has anyone else found a mounting fitted without a gasket?
Niels Jonassen
Re: Oil loss
Reply #1 on:
26 April, 2018, 04:12:45 PM »
I have to correct myself. Thee was in fact a gasket behind the engine mounting. It was only so flat and compressed that I did not see it till I began cleaning the surface. The mounting is now back in place. I'll do some cleaning before I refit the radiator.
Re: Oil loss
Reply #2 on:
27 April, 2018, 05:14:32 AM »
I don't understand why this joint should suddenly start leaking after being fine for so long. Are you sure you haven't got another leak or that you are not burning oil? And have you started using a thinner oil?
Niels Jonassen
Re: Oil loss
Reply #3 on:
27 April, 2018, 08:42:50 AM »
Oil was dripping at a constant rate from between the mounting and the engine, but only when the engine was running. I know that I am not burning oil, and the loss began when - as usual - i was running on 20/50 oil. I shall have to wait till I have refitted the radiator to see if I have solved the problem. I, too, found it strange that oil began to leak. I shall keep you informed.
Brian Long
Re: Oil loss
Reply #4 on:
28 April, 2018, 10:05:00 AM »
A comment not directly related to tour oil leak. There is a little plug inserted into the block behind the engine mount which locks pressure behind the chain tensioner when the engine is stopping. Watch that it hasn't fallen out and that it is put back in the right way around.
Regarding the leak, gaskets can harden, stud tensions can relax. A new gasket and good gasket cement should fix it.
Niels Jonassen
Re: Oil loss
Reply #5 on:
01 May, 2018, 03:15:22 PM »
Everything back in place and no oil leak. I was aware of the little plunger and made sure that it was in place.
Pages: [
1
Go Up
« previous
next »
Please select a destination:
General
=> About the LMC Forum
=> General Chat
=> Competition Information
=> Events 2024
=> Events 2025
=> Local Events
=> LMC Legends
=> Links
=> Pre-Lambda
=> Lambda
=> DiLambda
=> Artena and Astura
=> Augusta
=> Aurelia
=> Appia
=> Flaminia
=> Flavia
=> Fulvia
=> Stratos
=> Beta and Montecarlo
=> Gamma
=> Delta and Prisma
=> Ypsilon, Musa and Y10
=> Kappa
=> Thesis
=> Delta (2008-)
=> Commercial Vehicles
=> Other Lancia Models
Buy, Sell and Search
=> Members' cars for sale
=> Lancia vehicles for sale
=> Lancia vehicles required
=> Spares for sale
=> Spares required
Events Archive
=> Events 2011
=> Events 2012
=> Events 2013
=> Events 2014
=> Events 2015
=> Events 2016
=> Events 2017
=> Events 2018
=> Events 2019
=> Events 2020
=> Events 2021
=> Events 2022
=> Events 2023
Loading...
