21 December, 2024, 01:05:12 PM *
Author Topic: Steering box - oil  (Read 4402 times)
colinw
« on: 01 May, 2018, 01:12:27 PM »
I would like to change the gearbox oil on the steering box on my 1800 Flavia Coupe but as yet the drain plug? has not revealed itself.  Sorry to ask such a basic question but can anyone help? Thank you
Angle Grinder
« Reply #1 on: 01 May, 2018, 02:45:44 PM »
You'll need a big syringe and a bit of tubing to suck it out, but I suspect most unrestored Flavia steering boxes have seals that let the oil seep out. I use a Penrite product that has a viscosity somewhere between oil and grease. If you warm it up it will pour into the steering box and then it "sets" with a viscosity that prevents it leaking out past old seals.
Previous cars:
1983 Prisma 1600
1991 Thema 16v i.e. SE
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1983 Gamma Coupe (manual)
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
colinw
« Reply #2 on: 02 May, 2018, 05:59:36 AM »
Thank you for the reply. As I suspected and you confirmed one would have to remove a flange and seal to drain the box. Interesting idea about using a thicker oil. Can you let me know the viscosity?
Syringe idea is interesting I shall give it  try. Have cleaned up the box and now I look for the potential leaks.
Thank you again
« Reply #3 on: 02 May, 2018, 07:02:51 AM »
Thank you again
I use EP140
Angle Grinder
« Reply #4 on: 02 May, 2018, 01:41:38 PM »
I think it was this product, but I'd need to have a look in the garage to check what bottle I've got.  https://www.penriteoil.com.au/products/steering-box-lube
Previous cars:
1983 Prisma 1600
1988 Thema 8v Turbo
1992 Thema 16v i.e.
1993 Thema VIS
1994 Thema VIS LE
1990 Thema 2.8
JohnMillham
« Reply #5 on: 02 May, 2018, 05:40:10 PM »
That's what I have used for years in the Lambda and Augusta. They used to leak, but don't any more.
colinw
« Reply #6 on: 02 May, 2018, 07:56:08 PM »
Many thanks to all of you and the recommendations, I shall follow it through and hopefully another part of my Coupe shall become leak free.
