Hi Chris,
I agree with you on the positioning of the mirrors on top of the wings, they're much too far inboard to see a lot!
Back in the 1960's one of the OEM Manufacturers of wing mirrors had a wing mirror the you could undo a screw at the back of the arm, that allowed the arm to be rotated so you could extend the mirror itself outwards, so it being fitted on top of the wing wasn't a problem, but to move these onto the side of the wing means filling holes in a prominent position, so perhaps better to live with them.
I know many owners have changed the series 1 mechanical fan for an electric fan, as the electric fan is more efficient and makes less noise! However I've never been tempted as I think the series 1 pillar and fan are such a lovely work of art, and to be honest I've never had a problem of it not doing its job, even climbing the Alps or the Pyrenees.
Just wondering if Dellorto 35's are a bit big for the 1231cc engine, or did it have 35 solexes as standard?.
I fitted 32 DHLB's to Fay about 15 years ago and they are so much nicer than the Solexes, purely from being better built, there's never been an improvement in performance, but Fay runs so much nicer on them, and I can't remember the last time I had to have them tuned.
My Eagle eye missed the wire for the electric fuel pump, but it did notice the missing fipsa sticker on the air cleaner😲.
I have an electric fuel pump just for priming, otherwise the engine churns over forever before starting, while if I prime the carburettors first, she starts first time, unlike most pump isn't visible and is mountedcc adjacent to to fuel tank.
It's also handy to have it as backup in the fairly unlikely event of a problem with the mechanical pump.
It may just be a coincidence but my engine was totally rebuilt at 28,000 miles when a Piston ring broke and scored a bore, however when the engine was stripped, there was also an oil leak between the crankcase and block adjacent to the oil filter, where the oil passes through the gasket to the head, on early cars, Fay was built halfway through 1965, the oil pressure could push the gasket sideways causing an oil leak.
Lancia brought out a modification to the crankcase face to add a roll pin at this point which allowed the oil to be fed up through the hollow pin, but the pin stopped the gasket being moved by the oil pressure, I have a copy of the bulletin for the modification and I think, without looking, that another pin was added on the other side as well.
While the engine was being rebuilt the modifications were carried out.
I would have thought that by the time your 1231cc engine was built that problem would have been long gone, but you never know.
Once again Chris it is beautiful and I'm very envious.
8227
