27 November, 2024, 08:24:28 AM *
Author Topic: New Fulvia 32mm rubber carburettor mountings  (Read 4285 times)
« on: 29 May, 2018, 12:47:26 PM »
I have a few new unused OE 32mm rubber carb mountings for sale.As far as I can see these sell for around €150 + VAT + P&P per pair and they are not always available so how does £100 for a pair including delivery within the UK sound?
I will leave these on the LMC forum for a week and if not sold, ebay beckons which is also the case for the other Fulvia bits i have put on the forum in the last 2 days.
cannylancia
« Reply #1 on: 03 July, 2018, 10:54:06 AM »
Hi Chris trust you got my payment for the lock + key.
I'm sorting out the fuel system on my car and wonder which carb mountings you've got. The carbs on the HF are I understand mounted on a one piece adapter from inlet manifold to carbs all sealed with gaskets.
Regards
Alistair
« Reply #2 on: 03 July, 2018, 04:56:15 PM »
Hello Alistair,
Thanks for payment for lock and keys . My local ferramenta has run out of the correct key blanks and they are not due in till the end of next week so as arranged I will be sending you your lock and keys on August 10th.
Regarding carb mounts, if you have a 1600HF you will need 35mm rubber mounts, not 32mm?
32 mm is the standard size for 1298cc Fulvia engines and smaller I believe.
« Reply #3 on: 03 July, 2018, 10:53:14 PM »
Chris I maybe wrong, but if I remember correctly my Fulvia 1.3 Rallye Coupe had Solex 35 phh Carburettors and 35 mm rubber mountings to match.
8227 Cool Cool
« Reply #4 on: 04 July, 2018, 07:14:19 AM »
Just to be clear. 1600hf with 42 standard solexs requires a rubber mount to match i.e. 42mm openings tapering to inlet manifold diameter. These are available but at a price. You may be able to open up smaller rubber mounts to match 42's but very difficult....
« Reply #5 on: 04 July, 2018, 09:03:18 AM »
Sorry for any confusion. I realised I was wrong shortly after I wrote my previous posts but I couldn't remember what size carbs 1600 HF had. Our GTE which is 1298cc has Solex 35s and the GT which is 1231cc originally had Solex 32s although its now on Dellorto 35s with corresponding mounts and opened out inlet manifold.
So the new 32mm rubber mounts I have are for Fulvias with 1231cc or smaller engines.
Page created in 0.082 seconds with 20 queries.
