14 December, 2024, 11:35:50 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Project for sale - with an MGA engine?  (Read 17698 times)
0 Members and 15 Guests are viewing this topic.
Lojzik
« Reply #30 on: 10 February, 2021, 05:24:11 PM »
Thank you both for the photos, they are very useful.
Kari, may I ask you for the measure shown on the photo?
Kari
« Reply #31 on: 11 February, 2021, 08:58:35 AM »
The height of the crossmember is 90 mm. It extends and is welded to the diagonal U-profiles inside the boot.
Regards  Karl
Lojzik
« Reply #32 on: 15 February, 2023, 09:44:55 AM »
Hi everyone, I am still making progress with the rebuild of my Lancia, attached is a photo of the present state. I have a problem with the left rear wing which does not sit in properly whed aligned with the front wing and the running board. May I ask for the measurements as per the attached photos?
Kari
« Reply #33 on: 15 February, 2023, 05:07:27 PM »
Hi,
I can confirm measurements as follows:
Photo WA0069 = 920 mm
Photo WA0072 = 1190 mm
Photo WA0075 = 1290 mm
If you haven't done already, I suggest following: car on stands, draw a center line accurate on the floor length wise. Draw lines left and right parallel to the center line at a distance of 725 mm. This is the outline of the car. With the aid of a plumb line you can check symmetry and right angles of mudguards and running board.
I hope that helps.
I note that your rear axle is from a convertible. There is a spacer between the spring and the axle, the convertible sits a bit lower than the berlina.
Karl
Lojzik
« Reply #34 on: 16 February, 2023, 09:05:27 AM »
Hi Kari, thanks for the answer. You have confirmed the measurment on photo 0069 as 920 mm, but we have measured 820, may I ask you to check it again? Also may I ask for the dimensions between the rear spring hangers and the width of the rear wing as per the photos.
Kari
« Reply #35 on: 16 February, 2023, 05:16:20 PM »
I am sorry, its 820 mm.
Please find attached some data which could be of use. The distance between the springs is measured at the inside edges of the main blades.
Karl
Lojzik
« Reply #36 on: 18 February, 2023, 03:25:48 PM »
Thanks Kari, your advice is very helpfull
Pages: 1 2 [3]   Go Up
Page created in 0.032 seconds with 20 queries.
