Author Topic: E55 LBR the parallel project  (Read 137394 times)
  • Permanent resident
Re: E55 LBR the parallel project
« Reply #195 on: 09 July, 2021, 10:46:22 AM »
That's good. NOS is always the best way to go.
  • Slow but rough
« Reply #196 on: 16 July, 2021, 06:31:08 PM »
New hose arrived today and is now on the car not bad for £30 delivered to the door all the way from Cyprus!
  • Slow but rough
« Reply #197 on: 16 July, 2021, 06:32:09 PM »
Looks a bit more hefty than the last one...
« Reply #198 on: 16 July, 2021, 06:42:27 PM »
That should last a bit longer.
  • Slow but rough
« Reply #199 on: 01 August, 2021, 07:42:59 PM »
Had a play with the distributor today as I had a spare one so that was cleaned up and the resistance of the sensor checked and found to be with in tolerance so we put it in. On taking the other one out found it was held in by just one nut so a bit of timely maintenance? Anyway the replacement one must be shot as the car would hardly run so the original went back in after a quick clean of the rotor arm and the contacts in the dizzy cap. Well you could have knocked me down with a feather the little scamp started without the choke and seemed to be revving for fun...so a new dizzy cap will have to be sourced and we shall attempt to fix the leaking exhaust and give it a thrash round the compound for a few laps.
Kevinlincs
« Reply #200 on: 01 August, 2021, 09:34:24 PM »
Fingers crossed you've found the issue  8)
Flavia 815 coupe
Delta integrale
  • Slow but rough
« Reply #201 on: 03 August, 2021, 07:28:23 PM »
Out out of interest has anyone an idea what the static advance would be on a 4x4 engine as that is what is fitted in the car and at the moment it is set at 2 degrees.
« Reply #202 on: 04 August, 2021, 08:30:10 AM »
As far as I am aware there was no special engine for the 4x4 so it's the same as an ordinary Y10.
  • Slow but rough
« Reply #203 on: 04 August, 2021, 06:42:31 PM »
It has 5bhp more and another 500 revs to play with!!!
« Reply #204 on: 05 August, 2021, 08:00:49 AM »
That's interesting, checking Wikipedia I see that now. Rechecking all my manuals I see the 4x4 isn't acknowledged in any of them nor does the Panda 1981 to 1995 Haynes Manual. However the 2 deg. static seems to be common to all versions of the Fire engine up to and including the 1.1 injection. Perhaps a call to Trevor Nicosia would confirm the right figure.
  • Slow but rough
« Reply #205 on: 05 August, 2021, 08:41:53 PM »
Thanks Frank...I can't find any info apart from what is on the Y10 club it site http://www.y10club.it/Y10CLUB/1a/Modelli/4WD/Y10_1_4WD.htm
« Reply #206 on: 06 August, 2021, 09:23:45 AM »
Damn you Mr Clarke. That's another web site that will distract me from spending my time being productive!
  • Slow but rough
« Reply #207 on: 06 August, 2021, 09:28:47 AM »
Found another one with a pukka 4x4 panda workshop manual plus lots more in Italian
« Reply #208 on: 06 August, 2021, 10:20:49 AM »
It would be very interesting to know if the 4x4 manual shows how the extra 50 hp is created.
« Reply #209 on: 06 August, 2021, 11:39:22 AM »
769cc      1000cc    1000cc
25kw         33kw       37 kW
34cv           45cv        50cv
Rpm
6250         5000       5500
Max torque eec
daNm
5.7            8.0            7.8
Kgm
5.8             8.2            8.0
Rpm
3000         2750         3500.
I have  The New Panda Fiat Manual.
Covers
Panda 750
Panda 1000
Panda 4x4
For Sale £50 +p+p.
827 8)
