26 November, 2024, 09:40:17 AM *
Author Topic: Fulvia fuel cover  (Read 2646 times)
cannylancia
« on: 20 August, 2018, 07:32:33 PM »
Has anyone changed out the fuel filler cover on a Fulvia HF. I had to cut mine due to a broken lock and was wondering if it is possible to take the 5mm vertical pin out and replace the cover. Looks almost impossible to me Huh?
« Reply #1 on: 20 August, 2018, 07:58:50 PM »
It can be done, there is vertical pin and from memory a spring there too, many  fits between the two horizontal 'runners' there are one or two rubber grommets you can get from inside the boot to remove the pin, a good torch or headlight is required.
« Last Edit: 21 August, 2018, 12:51:09 PM by Neil » Logged
386
1973 Fulvia S2 1.3
cannylancia
« Reply #2 on: 21 August, 2018, 12:25:26 PM »
Many thanks - will have a look and try.
