Hi all,
I've had my Zagato Fulvia for a week now and thoroughly enjoying the experience so far.
However I do have a question about what can only be described as "shunting" of the engine/transmission when applying and releasing the power.
The engine mounts are pretty new, the gearbox lower mount is new, and has no loose movement in it. The gearbox support mount looks ok but may have some bagginess in it and the little torque reaction "foot" needs a bit of adjustment. Lastly the subframe mounts all look ok but may have a bit of slack in them.
So my question....what should I be looking at to fix this issue and make the driving experience slightly smoother and more enjoyable. Is it an issue common to the Fulvia or is this viewed as normal ?
Would appreciate any help or advice.
Thanks & regards,
Michael.
