Author Topic: Y10 new owner  (Read 49436 times)
  • Permanent resident
  • Slow but rough
Re: Y10 new owner
« Reply #45 on: 27 August, 2019, 11:03:08 AM »
It is already too late...
Kevinlincs
Re: Y10 new owner
« Reply #46 on: 27 August, 2019, 08:01:34 PM »
 ;D. Yes, I think you're right... It's got me in its claws already  :D
Flavia 815 coupe
Delta integrale
Re: Y10 new owner
« Reply #47 on: 27 August, 2019, 08:11:05 PM »
If it has to come apart it might as well get cleaned and refurbished. That way the car just gets better and better. I was sad not to be able to make it to the AGM.
  • Slow but rough
Re: Y10 new owner
« Reply #48 on: 28 August, 2019, 07:59:28 AM »
those anti rollbar bushes can they be replaced without taking the rollbar out? I have some replacement ones and while the front end is up on stands...
Kevinlincs
Re: Y10 new owner
« Reply #49 on: 28 August, 2019, 08:46:11 PM »
yes, they can.
In fact it's easier to do them with the car on its wheels as it all aligns up better, the bushes have a split in them so can be folded over the roll bar. Be sure to use plenty of red rubber grease to ensure they last..
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Y10 new owner
« Reply #50 on: 28 August, 2019, 08:57:16 PM »
Thankfully the little Y10 now has an mot, new horns fitted so it has a nice high / low tone than just makes the right sound.
When I gave it a wash though the water was running on the inside of the hatch glass...
The sealant at the top edge was somewhat lacking, the glass could be flexed away from the hatch!
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Y10 new owner
« Reply #51 on: 28 August, 2019, 09:02:21 PM »
Pulled out the outer seal and filled with bonder, it'll be OK until the refurb is done, it'll stop water getting in but also stop the glass falling out down the road!
With that done I gave it a polish, chuffed with how it came up, not perfect but perfectly presentable.
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Y10 new owner
« Reply #52 on: 28 August, 2019, 09:03:55 PM »
It has some rust around the sunroof opening that I'm sure will be a challenge to weld up but I'll worry about that another day..
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Y10 new owner
« Reply #53 on: 28 August, 2019, 09:06:05 PM »
Even gave the carpets a scrub which came up pretty decent..
Flavia 815 coupe
Delta integrale
Kevinlincs
Re: Y10 new owner
« Reply #54 on: 28 August, 2019, 09:07:04 PM »
Loving the soft green lighting
Flavia 815 coupe
Delta integrale
Re: Y10 new owner
« Reply #55 on: 30 August, 2019, 06:10:49 PM »
Looks a million dollars!!!!
Can't wait now for "on the road" photos.
Re: Y10 new owner
« Reply #56 on: 30 August, 2019, 08:28:52 PM »
I felt the carpet rather let the rest of the car down. Lancia's tufted carpet of this era was cheap and nasty in my opinion and the light grey shows marks dreadfully. I much prefer the black more felted carpet in the lesser versions. It sets off the lighter coloured seats nicely and doesn't show marks.
  • Slow but rough
Re: Y10 new owner
« Reply #57 on: 01 September, 2019, 04:57:09 PM »
love the seats...what did you use to clean the dash and door Alacantara panels with?
Kevinlincs
Re: Y10 new owner
« Reply #58 on: 01 September, 2019, 07:01:32 PM »
I've not done anything more than a damp cloth on the alcantara bits, carpets got scrubbed with some simoniz foaming carpet cleaner that I got given.
The black plastics got a scrub or two with good old Mr sheen!
For the windows I don't waste money on fancy expensive glass cleaner. Often just use neat screenwash on a cloth but I recently treat myself to a large spray bottle of window cleaner from The Range shop, best £1 I've spent in a while
Flavia 815 coupe
Delta integrale
Re: Y10 new owner
« Reply #59 on: 01 September, 2019, 08:55:59 PM »
You're OK to use soap and water on Alcantara as long as you don't go mad :D
8227  8)
